CivicMike93
07-11-2007, 11:05 PM
Im selling a 15" MA Audio Sub and MA Audio 800w MonoBlock amp. It is in really good condition its only a few months old. I will sell it for $125/OBO give me an offer. I NEED TO SELL IT A.S.A.P. Give me a call at 727-422-8969 or PM me if your interested and i will send you pics. Here are some of the specs on the sub and amp. Thanks
MA Audio 15" sub (MA150XE)
450W Rms 900W Max
Dual 4-Ohm Voice Coils 150oz.
Double Stacked Magnets Mounting Depth: 6.6
Mounting Diameter: 13.9
Optimum Vented Box: 4 Cu/Ft
Round Port Diameter: (3)
Square Port Area: 37 Sq/In
Port Length: 15.5
Optimum Sealed Box: 1.5–1.7
MA Audio 800W mono-blocked amp (M1889I)
Selectable Bass Boost (0db, 6dB, 12dB) 50Hz - 250Hz
Low Pass Filter 1 x 400W Rms @ 4 Ohm Mono 1 x 800W Max @ 2 Ohm Mono
Fuse Rating: 25A x 2
Dimensions: 13" L x 9.5" W x 2" H
Overload, Short and Thermal Protection Circuit Frequency Response: 20 Hz - 20 kHz
Full Mosfet Circuitry Selectable Bass Boost @ 50Hz 50dB
Channel Separation 90dB
Signal Noise Ratio 22K Ohm Input Impedance 200mV-2V
Input Sensitivity THD <0.05%
450W Rms 900W Max
Port Length: 15.5
