Exhaust Issues
Old Jul 5, 2007 | 03:05 PM
joy and bill's Avatar
Default Exhaust Issues
My 2003 Eclipse [4 cyl] has seemed to have a clogged [cat. converter]. As always, it is NOT the rear one, it is the one off the manifold, to which the dealer here in advises that the replacement cost is $764.00, [not including installation]. The (2) local exhaust shops have told me that this FORWARD converter is FACTORY ONLY. HELP>>>>>>>>>>>>>>>>>>>>
Is there a replacement front converter out there somewhere that is not cost prohibitive. I am disabled and have only so much money to spend each month. I realize that the EPA rules come into factor here, but there MUST be something I can do to bypass the computer...................
Much thanks for your input...........
Bill
Old Jul 5, 2007 | 04:45 PM
Figs's Avatar
As far as I'm aware of Eclipse's only have (1) Catalytic Converter anything else that resembles it would be a resonator (dampens the sound of the exhaust system).
Are you throwing a check engine light? I don't see how its a bad catalytic converter, its possible but I don't see how. If your check engine light is on I would go to Discount or somewhere that has a obdII scanner and check what the CEL code is. If its a bad O2 sensor then thats better then it being the catalytic converter.
If you truly need a catalytic converter go here...
Club3G
That's a website for the 3g Eclipse in which case your 2003 is one. I'm sure somewhere on that website/message someone is selling a catalytic converter or knows of a place to get one new or used. There's also a few locals on there that may be some help.
I've heard of dealerships asking for that much on catalytic converters, your best bet would also be calling a bunch of places to see if they have them or can source one out for you. Did you try calling some autopart stores? It wouldn't hurt to try.
Just trying to help. Hope atleast one thing I mentioned helps you.
Old Jul 5, 2007 | 08:32 PM
BoostLogik's Avatar
BoostAddict
You can always try searching the local junk yards for a cat converter, if all else fails. (if that ends up being the part that needs replacing)
"Even through the darkest days, this fire burns, always"
Old Jul 7, 2007 | 07:59 PM
DC Dave's Avatar
Heavy Artillery Co.
do you have a warrenty
