PDA
View Full Version : Need repair welding on 99 Sentra SE SR asap.
M374llic4
06-26-2007, 07:38 PM
Hello,
My clutch pedal mount has broke.
The bracket at the top of the clutch pedal, where it bolts to the metal underside of the dash broke. So you press the pedal and it does not actually depress, it just pushes the whole assembly. I went to the dealer today, and theres no actual part, the bracket needs to be repaired with welding.
Anyone know a shop or anyone on here that can do it, and how much??
I need it asap!
Dan
AIM - M374llic4
WagonMaster
06-26-2007, 07:46 PM
aztec welding call 518-7715 its where i work we are in largo
have the bracket out and mention tampa racing!
M374llic4
06-26-2007, 07:49 PM
Thats part of the problem : \
The bracket is welded under the dash, I wish it were as easy as bringing it in to a shop, someone has to actually lay down under the dash, and weld it up to the metal under the dash, it does not bolt.
M374llic4
06-27-2007, 01:02 PM
Can anyone handle this, or know a shop willing to do it? It is in car, in a tight space, but I would not believe to terrably difficult?
Let me know asap! Need it fixed!
AIM - M374llic4
813-210-3524 (dont get good signal here though)
ChrisN1313
06-27-2007, 02:53 PM
Largo Genium Performance Call dave at 727-234-7250
