View Full Version : Gold BBSs with worn tires off '05 STi...$650
The tires are BF Goodrich G-Force KDW II's. I quit using them when the tread touched the wear bars. The tires don't have much left in them, but you could certainly drive on them for a little while.
The wheels have never been curbed. They do have a few scratches around the edges of the rims (EDIT:only the paint is scratched off; the metal is fine) from the idiots at Costco not knowing how to remove tires. There are also a few little nicks in the paint from rocks, but nothing out of the ordinary for wheels that have been used for 45,000 miles. The comsetic blemishes aren't really noticeable unless you get real close and are looking to find them.
PM me if interested.
Michael.
06-24-2007, 05:28 PM
pics? and do you know what the offset is? ive always wanted to toss wrx wheels on my jetta. especially the bronze STi's
ryan_west06
06-24-2007, 07:09 PM
Im interested!
02'subie dude
06-24-2007, 07:38 PM
05' STi's are 5X114. Jetta's are X100. Unless you get spacers (which do look good on VW's) or pattern changers, they wont fit.
Michael.
06-24-2007, 07:51 PM
ohhh they did change the pattern? they used to be 100's iirc.
and yeah depending on the et's i would run the adapter cause the way im sitting on my coils now i cant have much poke in the rear cause i'll rub too badly. i need the final et in the range of ummmm, (trying to remember/calculate the numbers in my head)...range of 25-38 et
05stisilver
06-24-2007, 08:27 PM
[quote=civickid04;4311163]ohhh they did change the pattern? they used to be 100's iirc.
They changed to 114 in 05
Michael.
06-24-2007, 08:32 PM
so i see.
so whats the offsets, anyone know? cause if its what most jdm spec are like in the 60's then they make 25mm adapters all the time and that would make them fit perfect on the jetta
SilverRexH4
06-24-2007, 08:40 PM
I think the offset is 53
Michael.
06-24-2007, 08:47 PM
that could still work. the smallest adapter ive seen were 15mm, but those are a little sketchy. then usually a 20mm which would probably be my best bet...we'll see. doing all that is about another 3, 400 on top to get adapters.
Im interested!
I'm working out of town this week, but I'll be around this weekend. If you want them, or at least are serious enough to want to check them out, PM me your phone number. Same goes for anyone else that is interested.
Im interested!
The last bump.
Autobots.....rollout.
Content Relevant URLs by
vBSEO 3.2.0 RC5
