map sensor
Old Jun 23, 2007 | 07:15 AM
fallingeg6's Avatar
V8 this
Exclamation map sensor
i have an 3 bar map sensor, if i go all motor would i still need that map sensor? thxs
93 eg6 hatchback - sold 2,000$$
00 civic si - sold 8,000$$
93 del sol - sold 2,500$$
00 civic si - traded
95 civic ex - traded
95 prelude - trade-in
02 ram 1500 - stolen
92 eg6 hatchback - sold 1,700$$
05 srt-4
Old Jun 23, 2007 | 07:27 AM
fallingeg6's Avatar
V8 this
Ttt
05 srt-4
Old Jun 23, 2007 | 08:25 AM
JoKiE crx4294's Avatar
popeye built!
no you need your stock map
Can't spell strength without tren
AAS...It's whats for dinner
Old Jun 23, 2007 | 09:05 AM
fallingeg6's Avatar
V8 this
well i dont have the stock map, because i have eldlebrock ITM and had to switch to a 3 bar
05 srt-4
Old Jun 23, 2007 | 09:11 AM
itsslow's Avatar
I-VTEC, do you?
if you have the Edlebrock VictorX mani, i would swap that out anyway if your going all motor, unless you plan to rev till around ~9500. That mani is mainly for high range power (6000-10000 rpms) which i belive would be bad for a all motor setup, but then again, im not an all motor guy, so maybe an all motor guy could chime in here.. I would try more of a SK2 intake mani.
also for all motor you will need the stock map sensor, seeing as you will not see any boost...
Old Jun 23, 2007 | 04:56 PM
mtber's Avatar
Your intake manifold really should not have to do anything with what map sensor your running.
You can run a stock throttlebody with a stock map sensor on a victorx manifold such as the one you have.
If you have a aftermarket throttlebody that does not have provisions for a factory map sensor, you can simply run a vacuum line from the intake manifold to the map sensor and mount it on the firewall.
Old Jun 23, 2007 | 05:19 PM
fallingeg6's Avatar
V8 this
yes i have one on the firewall already, so i'd be fine with the stock TB?
05 srt-4
Old Jun 23, 2007 | 05:51 PM
Liquid's Avatar
^ your ghey!
Old Jun 23, 2007 | 07:13 PM
popeye built!
Your Car Will Not Run With The 3 Bar. Already Have Tried It
Old Jun 23, 2007 | 09:24 PM
mtber's Avatar
I already answered your question.
It will if it is properly tuned for the setup/injectors. Runing a 3bar map sensor on an na car is a waste of a 3bar.
