Nycist
06-20-2007, 08:33 PM
buddy of mine just blew one of his hx2s. sellin the rest of the system...
bd1500 - $400 obo
the amp does 1642 watts at 13.5 volts not at 14.3 volts most cars push.
Class bd technology
750 watts RMS x 1 at 4 ohms
1500 watts x 1 at 2 ohms
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz)
subsonic filter removes frequencies below the range of human hearing for increased efficiency
dimensions: 18-1/2"W (13-11/16" without endcaps) x 2-7/16"H x 9-7/8"D
http://images.craigslist.org/01010001020401030420070621b9603168e9ef3505e1008e83 .jpg
15" power hx2 - $100 obo
Dual 3" 4 Layer LXtended 4ohm Voice Coils
Coil on Aluminum Former
FIBERLock Cone
Hyper XTended Pole Piece
LXcursion Cast Frame
Dual Laminated Progressive Flat Spider
BART Surround
CONsealer gasket hides mounting screws and provides an airtight seal
Aeroport Exhaust
Rubber Magnet Boot
Frequency response 24-200 Hz
RMS power handling: 600 watts RMS (250 watts per voice coil)
peak power handling: 1200 watts
Sensitivity 89 dB SPL
Top mount depth 6-15/16"
Sealed box volume 2.25-5.0 cubic feet
Ported box volume 2.0-4.0 cubic feet
Impedance 4 ohms
Peak Power Handling 1200 watts
RMS Power Handling 600 watts
Woofer Surround Santoprene Rubber
Woofer Composition N/A
Sealed Box Volume 2.25 - 5.0 cubic feet
Ported Box Volume 2.0 - 4.0 cubic feet
Sensitivity 89 dB
Frequency Response 24 - 200 Hz
Xmax (millimeters) N/A
Top Mount Depth 6-15/16"
Cutout Diameter 13-7/8"
http://www.sonicelectronix.com/images/normal/rfr3112.jpg
lmk..
bd1500 - $400 obo
Class bd technology
FIBERLock Cone
BART Surround
Aeroport Exhaust
Rubber Magnet Boot
Impedance 4 ohms
Sensitivity 89 dB
lmk..
