View Full Version : Anyone Know Where To Fix Amps
94civicb16
06-05-2007, 12:56 AM
I have a amp that stopped working and i was wondering if anyone knew where i can take it to fix it... or if anyone can fix it. Its a power acoustik 2400d. lmk guys.. id like to get it going again, it doesnt go in protect, it just doesnt do anything when i connect speakers, could this be a easy fix?
Usually not worth it I have found. Used to be a place in South Tampa but I don't even think they are around anymore and they were prohibitively expensive! If you find someone, post and let us know. Good info for everyone...
94civicb16
06-05-2007, 02:31 PM
Well i know a place in tampa, but they charge 20 just to tell you whats wrong with it.. cost me 120 to fix a brutus 1600d amp before.
My Honda Is Slow
06-05-2007, 08:11 PM
i need a place too. i already know whats wrong with mine i just need it re- soldered or something
dassip
06-11-2007, 02:26 AM
hey were do u get a kicker amp fixed its underwarrenty
Notladstyle
06-11-2007, 11:27 AM
I can do board soldering down to 3mm at work. I might be able to do it for you, what do you need soldered?
My Honda Is Slow
06-15-2007, 06:56 PM
thats the problem i opened it up to find the problem and cant see it. ok heres the deal, the rca inputs are loose, like the connection on the board is loose. when i hook up my rca's and turn the radio on i have hold them either up or to the side for them to work, but when it works its a bad ass amp with plenty of power and rarely gets hot. i dont want to get rid of it, i have a peice of folded up paper wedged inbetween the rcas to hold them apart but thats ghetto and i want to fix it
Notladstyle
06-15-2007, 11:35 PM
Just use the piggyback from an RCA rable and solder it in. It's a 5 minute repair. Here are pics.
OR you could buy the correct jack from radio shack(its an identical replacement) but this would usually mean removing the board and that means pulling the heat sinks off the fets and reseating those is VERY difficult and usually they wont conduct heat as well as they do stock.
If you want me to do it for you let me know where I can meet you and ill pick it up and solder it in.
http://notlad.ath.cx/%7Epics/mtxamp1.jpg
http://notlad.ath.cx/%7Epics/mtxamp.jpg
tphitterlude92
06-16-2007, 10:43 PM
just soldering it isnt bad i did it on my kicker amp that had expired the warrenty two weeks before it shit out and it was very easy to fix... just get a mag glass and some small solder
94civicb16
06-18-2007, 12:04 PM
anyone know how to fix a blown channel???
Content Relevant URLs by
vBSEO 3.2.0 RC5
