PDA
View Full Version : V8 In 2nd Gen RX7 - Need Quote FAST
Teggy_Boy
05-30-2007, 05:13 PM
Basically what I am looking for is a quote on parts & labor for a carburated small block Chevy or Ford motor and a manual transmission to be fabricated into a 2nd or 1st Gen RX7. I want a turn-key swap done, along with anything necessary to keep it running safe; exhaust, radiator, carb tuning, fuel upgrades. No need for power steering or A/C. I called a "local shop" for a quote, and I was told **$13,000 at least** ... I think this price is RIDICULOUS... The same shop charges about $10,000 to put an LS1 into a 240sx, and that swap isn't NEARLY as documented or straight forward. Can someone help me out with a decent quote? You can either PM me or post it up here. Also, if you have any questions about the swap that will help generate an accurate quote, feel free to ask
Thanks in advance
Teggy_Boy
05-31-2007, 06:25 AM
No one? I have no clue what shop on here would be up to this. And it's not even that difficult or rare of a swap...
Teggy_Boy
06-01-2007, 01:53 PM
Can anyone point me in the right direction?
BACON
06-01-2007, 03:02 PM
you can do it for a little under 10k if you do it yourself
Teggy_Boy
06-01-2007, 08:10 PM
LOL... 10,000? What is with these crazy numbers I'm hearing? A stock carb'd SBC motor and trans for about $1,500, Premium/Deluxe install kit from Granny's Speed Shop for about $2,000, Other things like, carb, fuel components, cooling system upgrades, maybe about another $1,000... That's $4,500 to be GOOD TO GO... I can't imagine a $5,000 labor cost for a bolt in installation and minor wiring
rexaholic7
06-01-2007, 10:16 PM
ask in the mazda forums. sneacon deacon will pop up and let you know everything or at least something. i wouldnt doubt it if he tells you the same thing bacon did.
power2weight
06-01-2007, 11:11 PM
Bolt in installation?
Minor wiring?
Have you ever done an engine swap?
351coupe
06-01-2007, 11:18 PM
Minor wiring?
uh,he said a carbed small block
Teggy_Boy
06-01-2007, 11:39 PM
Thank you for reading +1 to rep
power2weight
06-02-2007, 01:45 AM
i hate the fact im left to literally piecing this thing out like i am, but i have no choice now, i understand its not the prettiest thing, but almost everyone says they want to go fast, yet there is a 10 second car sitting in my driveway and im only asking 4500 for it when it has over 10k into it easily.. but with all my paramedic/firefighter stuff going on right now im not going to have a job for another 2 months, and fishing is getting slow to the point im barely able to pay for gas when i go out, so i have to do whatever will bring me some income.
i had to wire up:
Fans
ignition
water pump
starter
alternator
battery
oil pressure switch
just remember, your going to need turn signals, caution flashers, horn, interior lighting, etc.
:deal:
Teggy_Boy
06-03-2007, 02:52 AM
For a shop I would consider that to be basic wiring.
ZCHatchback
06-19-2007, 09:29 AM
Castillo Auto Repair in Plant City, FL ph#813-707-8881.
They can put a 302h.o. in there for less than about $3000 turn key price. He builds custom race cars and can fabricate mounts and chasis.
He won 1st place at Nopi at Bradenton a few years ago with his suzuki samurai with a ford turbo setup and he has built another samurai with a chevy 350.
ZCHatchback
06-19-2007, 09:31 AM
Chevy ls motors are more expensive but get better results. For the money I would go with a stroked 302 and boost it.
Teggy_Boy
06-25-2007, 10:21 AM
Calling now.. thank you
Teggy_Boy
06-25-2007, 10:22 AM
I have to call back later when the owner (Willy Castillo) is there
ZCHatchback
07-09-2007, 06:35 PM
If that works out for you give me rep points ;)
