fuse :: maxi vs agu vs anl vs other
I've been reading up on fuse types or at least trying to and well I'm coming up with no conclusions. I've always used agu style fuses and blocks for my power on my cars because thats what i was easily available, but I'm wiring up a buddies and he has the choice of the three and i can't really find any pros or cons to any of them. to me they each do the same and there seems to not be much of a difference other than 'style'. what are yalls choices and any pros cons or links with more info etc... so i can help him make a choice.
just a quick run of which fuse is which:
ANL
MAXI (the big one in the picture)
AGU
thanks guys any help will be appreciated
ANL
AGU
AGU is by far the worst, stick with the maxis or blades and the anl's.
they are much cheaper and are capable of more throughput for bigger installs.
i've just always had a hard time finding larger sized AGU fuses... meanwhile i can find any of the other two anywhere.
just my opinion though.
I always used the agu for regular installs, but any high powerd I used the ANL.I have a 300amp anl running on my amps now and dont have any problems
I know the smaller maxi's are for low power but i just consider it more like this
maxi= low and high power (smaller vs big one)
AGU= low to medium
ANL=high
I think the maxi's and ANLs are just best choices because they're everywhere and really easy to install and remove.
AGU's are a pain in the ass and they're limited.
AGU= low to medium
ANL=high
I have more ANL fuses in my car than I care to count lol.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
I like Maxi's and the new Midi's, especially for anything over about 60 amps. I've had problems with AGU's where the fuse element isn't soldered or welded to the endcap well. I've also seen AGU holders (mainly the inline ones) melt because the connection to the fuse is loose.
Toby
Toby
I say MAXI for lower power because the majority that I've seen have always been severely distorted from being melted into their holder. I wouldn't ever trust one of those in a vehicle of my own. Coming in second in the melted category would be the AGU's (like Toby said, usually when the holder isn't secured properly...or it's rigged), and I don't think I've ever seen a melted ANL.
Now there's some logic!
