cooler fan switch for Teg?
Old May 9, 2007 | 11:07 PM
frominator's Avatar
Arrow cooler fan switch for Teg?
posted earlier about slightly high temp gauge readings with a new radiator/thermostat on my 94 teg.
fan is kicking in at a little over halfway and heats up for a few more seconds before the temp is brought back down by the fan. happens only at idle. took it back to my mechanic, confirmed the high fan is kicking in around 210-215. seems a little high? either way, i'd like it lower with the summer heat and crowded freeways.
can anyone recommend a new fan switch that kicks in at a little lower temp? saw one on ebay, always a tad skeptical... advance auto has a gp sorenson, but i dont know the temp on that, assume its stock. like i said, cooling system is working fine, i just would like to play the safe side on a hot day...
any suggestions are appreciated.
-k
Old May 10, 2007 | 02:25 AM
terry.ho's Avatar
I love to choke people.
Spoon low temp thermo swith and thermostat.
Spoon Sports
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old May 11, 2007 | 09:54 PM
I use adjustable t-stat switches, so I can regulate the time the fan
cuts on and off. I add in a switch that will disable the t-stat switch,
so it won't run down the battery and a sensor/buzzer to remind me that
it's working when I get out of the car.-Bob
