PDA
View Full Version : antenna booster?
ShakinIt
05-08-2007, 08:16 PM
Does anyone know if they make any kind of radio antenna booster? Ever since I got my Alpine HU, my radio reception sucks on a lot of channels in a lot of areas where it worked before....:roll:
or thoughts on how to make it better?
Aside from satellite radio.....
POST
05-08-2007, 08:36 PM
extra, powered antenna?
TBSpyder
05-08-2007, 10:14 PM
I'm sure there's something like that out there. I'll also bet it doesn't work all that great.
Notladstyle
05-08-2007, 11:01 PM
I would try running a new antenna lead to the antenna you have first - make sure you have an excellent ground on either end(there should be a braided wire coming off the antenna and ground the chassis of the alpine headunit).
I bet this will improve your reception
+1 to above, antenna boosters are garbage. if the signal isnt there all it does is boost static. most headunits has a +15db boost built in that auto adjusts itself so adding a static +10db is not going to magically make the signal appear.
