PDA
View Full Version : Need some help
me
04-28-2007, 04:05 PM
I was installing a radio into my friend's 93 Saturn and the radio he had (which was used) started acting up. It would cut off randomly and then every now and then come back on. So I installed a radio that I knew worked that I had, and all was good. Started driving and 2 min. later, it cuts off. It wont turn back on, nor will the stock radio. You can hear static coming from the stock radio and adjust the volume, but can't see the radio station or turn the radio station. I checked the fuse in his fuse box and it was fine. Anyone know why now I'm not getting anything?
Also when we were trying out the speakers (front left, front right, rear left, rear right) the rear speaker was still on when the front left only was turned on.
Any help would be great. Thanks in advance.
TBSpyder
04-28-2007, 05:15 PM
Try a different power source and ground.
me
04-28-2007, 05:32 PM
What other power source can I use? I'm use to just wiring up a harness and then plugging that into the factory harness.
Notladstyle
04-28-2007, 05:54 PM
saturns have weak ass grounds. try running the ground to a screw on bare metal of the frame.
POST
04-28-2007, 06:06 PM
if he can find any metal...
