View Full Version : Tire pressure PRO'S and CON'S
What tire pressure you guys run while drifting?
And why?
jonBODON
04-25-2007, 10:30 PM
if im on the street i dont normally check it cuase im fat and lazy.
if im going to the track, ill put about 32 or less in the fronts which are my more sticky tires anyways, and the back alken zeix's ill put about 40 give or take a lil.
but now its getin hot out ill prob put less in the backs
I have read that some pro drivers run as high as 65-75 psi in the rear. What benifit is that?
170k240
04-26-2007, 03:21 PM
less of the tire is touching the ground because it expands like a bubble. less contact surface = less traction
Ronald Mcdonald
05-06-2007, 03:07 AM
But it also makes the tire pop easier, cause less of the tire is touching the ground, cause uneven wear.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
