PDA
View Full Version : why my sub blew, plz help
smanrocks
04-23-2007, 10:58 PM
i have a 400w rms bumper sub
had another but it blew out
friend gave me a 1000w max volfenhag sub
had the 1000w max and 400w rms subs running off same channel on my amp
amp is audiobahn 800rms, 1600w max
and the volfenhag sub blew
started to smell like burning
so i took it out
then it completely stopped hitting
wtf?
JDMAddict
04-23-2007, 11:00 PM
is the amp a one channel?
smanrocks
04-23-2007, 11:03 PM
Amazon.com: Audiobahn A8002T 2-channel car amplifier 200 watts RMS x 2: Electronics (http://www.amazon.com/Audiobahn-A8002T-2-channel-amplifier-watts/dp/B0002CNPI0)
is the amp
the727kid
04-23-2007, 11:50 PM
You clipped it.
smanrocks
04-23-2007, 11:53 PM
i clipped it?
whats that mean?
the727kid
04-23-2007, 11:56 PM
Eh I'm too lazy to explain... go read Basic Car Audio Electronics (http://www.bcae1.com)
89crxsi3
thqat sub sucks i blew one i 2 days with a 800 watt amp those volfenhag sub suck
the727kid
04-24-2007, 12:07 AM
You shouldn't blow anything that quick unless you install it wrong or its a factory defect.
GradeA_TireFryer
04-24-2007, 10:21 AM
install and tuned wrong - wrong box for sub, dc the amp, or has no idea on what he is doing!!!!!!
the727kid
04-24-2007, 11:48 AM
Wrong box wouldn't lead to a burning VC.
POST
04-24-2007, 02:23 PM
It would if he made a very small sealed box, the VC would never cool if he was maxing it out, causing it to burn out/melt whatever...
GradeA_TireFryer
04-25-2007, 10:49 AM
o yes it would - to big would cause the sub to get out of contol of the ampa and flapp like a fish out of water
the727kid
04-25-2007, 10:59 AM
That would lead to a broken tinsel lead/suspension not a burnt VC, and that would be from not using a subsonic filter.
POST
04-25-2007, 01:54 PM
That explains his big box theory, now try to explain mine?
k4rts
04-25-2007, 01:58 PM
i highly doubt he was maxing out anything of his with the equipment he has/had.
POST
04-25-2007, 02:11 PM
Maxing out in the sense that he was at the highest volume he was able to put through... After a while of continuous playing the VC's would get too hot and just burn out, no?
Notladstyle
04-25-2007, 03:31 PM
how the hell do you install such high end equipment(and actually do a good job) and know nothing about what you install?
You are half right though, a small box would increase the resistance and further protect the subwoofer (to a point)
harleys
05-02-2007, 12:08 AM
distortion.
kapone
05-05-2007, 01:23 PM
Too little info to know what happen.... what music was he playing at what distor...sorry volume level, what deck was he using ....
the727kid
05-05-2007, 01:38 PM
How could a wrong size box burn up the VC? It could break the suspension, tinsel leads, ect. But maybe I am forgetting something?
the727kid
05-05-2007, 01:45 PM
Sorry didn't see this, if what you said was true than an Aperiodic Membrane enclosure would never work.
Notladstyle
05-05-2007, 04:54 PM
The box should be built so that the cone's movement will create air pressure behind it - a large box will have very little pressure to puch back against the sub. because of that the sub will be able to move further than its design.
once the sub extends beyond the magnet, the resistance in the coil will drop. The lower the resistance the more current that travels through the cone. More current = more heat = blown vc.
Subs with woven tinsel leads will probably outlast the voice coil in this situation.
