PDA
View Full Version : Need Vinyl Help...
TpaS13
04-22-2007, 01:09 PM
Alright i need some info on vinyling some fiberglass enclosures... i have 2 door panels that im am building and when i went to go vinyl it, it doesnt wanna stick or hold its shape....will get some pics of the work here in a few....
Rob
Notladstyle
04-22-2007, 04:05 PM
use some glue and a heat gun
TBSpyder
04-22-2007, 05:54 PM
First choice would be a glue you load and spray (using a compressor)...forget the name, second choice would be the aerosol cans of spray glue from Select Products. Use a heat gun to form the vinyl, and have at it. It's not easy and definetly requires some technique...especially with more sophisticated curves and such.
TpaS13
04-22-2007, 09:00 PM
well im using a heat gun and the 3m spray adhesive(can) and it doesnt seem to dry fast enough to stick on the tough curves...anyone have a video link or any link that may help??
rob
edmel89
04-22-2007, 10:05 PM
My dad does custom car interior, Ill try and get some pics up, he can cover the fiberglass for you, pretty cheap, espically if you provide it.
TpaS13
04-22-2007, 10:16 PM
sounds good talk to him and see what he can do...there small pieces only like 8x18 and maybe 6in high ill try to get pics...i have the vinyl as well just need them covered
TBSpyder
04-23-2007, 01:41 PM
The 3m spray glue is shit...about as good as the elmer's. Like I said, The Select works much better...but the stuff you use in an actual spray gun with compressor is the best.
TpaS13
04-23-2007, 03:09 PM
yea so i just found out that my job (CCity) has an account through select products...soo im prolly gonna try to order it from there i guess and buy a cheap gun from harbor freight....
burgy240
07-29-2007, 12:21 PM
did you ever end up doing this? I want to wrap my door panels and I want to know how the select products worked, where you got it, and for how much? thanks
integralsgreen
07-29-2007, 01:43 PM
3m spray is useless. u need some contact cement. spray it on both surfaces and let them tack. get a gallon of it at home depot for like 20 bucks. let it sit 72 hours befor letting it sit in the sun or get pretty hot or it will lift. also it helps it you put some 80 grit scratches on what you bonding to and clean it reall good with some wax and grease remover. select products has a heat activated glue that is good for extreme shapes but ive never found it nessesary. i use a vinyl from rochford supply that you can stretch all to hell witout geting a elephant skin effect, or much distortion in the grain. its strechability is insane makes life easy
heres a link
All Sport, Awning Material, Textiles, All Sport, Baypoint from Rochford Supply - Your Online Textile and Upholstery Superstore! (http://www.rochfordsupply.com/product_listing.asp_Q_CatID_E_419_A_SubCatID_E_489 _A_ProdID_E_3810)
oh and yes a siphon feed spray gun from harbor freight will work pefectly. i use mine every day for the past year and it was only like 15 bucks. i keep glue in it 24/7 and ive never had to tear it apart to clean it. then again i spray about a gallon of contact cement a week
*edit* i just realized this thread is a couple months old but ill leave my response in hopes someone will find usefull information
the727kid
07-29-2007, 06:34 PM
Yea you gotta spay the box and the vinyl and let the glue dry to touch on both and then put down.
TpaS13
08-02-2007, 05:24 PM
ooooohhh yea didnt get around to finishing them yet...still didnt get the vinyl....im going to gulf fabrics here son to pic it up ill put pics up asap
Rob
