View Full Version : rb20det swap
q8tkd
04-20-2007, 06:41 PM
i have a 95 s14, and am getting an rb20 engine .. can you give me an average of how much will it cost me if i do the swap at ur shop ?.. ill bring the engine and transmission
q8tkd
04-21-2007, 11:18 AM
JDMbyBlood
04-21-2007, 04:05 PM
Will get back with you Monday when Im at the shop. Do you have the Wire harness & ECU?
You will need:
ECU
Wiring Harness
Electric fans
Custom throttle cable bracket
Tach adapter or gauge cluster
The rest is direct bolt in.
q8tkd
04-22-2007, 12:54 AM
i dont have any of these just the engine and transmission .. so with that can you give me an estimate for the swap.
back2Nissan
04-22-2007, 01:07 AM
what about motor mounts??
You will need:
ECU
Wiring Harness
Electric fans
q8tkd
04-22-2007, 01:13 AM
this is what i have rb20 Complete Motor Complete Head & Block
Distributor, Intake Manifold Exhaust Manifold, Alternator Power Steering Pump Fuel Rail, Injectors Throttle Body, Turbo, 5 Speed Transmission.
how much will it cost me if i bring that with the car for a swap?
Either that or a R32 cross member
McLovin'
04-22-2007, 10:33 AM
well, I don't work there, but what they are saying is as it is, you do not have enough parts to get it into the car. You'll ATLEAST need to buy a mount kit or R32 x-member to get it to sit in there. To get it in and have it RUN, youll need what you have + ECU, Harness and the other stuff that Kirk listed. Good luck
q8tkd
04-22-2007, 12:23 PM
will the engine mounts from mckinneymotorsports.com work? or recommend me some places to get them at a lower price
Shadytrixta1
04-22-2007, 12:32 PM
I would say ebay an R32 crossmember or find an engine importer who might part with one.Mckinney is kinda pricey in my eyes.
SpottedMango
04-22-2007, 12:37 PM
We will for sure hit you up on Monday when we get in!
McLovin'
04-22-2007, 05:22 PM
mckinney v. r32 x-member...
Mckinney Motorsports
+Much easier to get yout hands on (from what I have seen)
+Some find it easier to put a mount kit in than a x-member
Cross Member
+Price
+There are some baller turbo setups that can be found, most of the ones from Japan wil NOT work w/ the mount kit, but usually do with the crossmember
back2Nissan
04-22-2007, 07:17 PM
Cross Member
+Price
And.... If you dont have the factory engine mounts attached to your engine, than you will also have to locate those to use the sub-frame. Mckinney Mounts +1 from someone who had one of the first sets made. Awesome fit and built much stronger than the competition.
q8tkd
04-28-2007, 03:01 AM
so any estimates? i think i can get the R32 cross member from ebay
Content Relevant URLs by
vBSEO 3.2.0 RC5
