View Full Version : LS1 into a toyota pickup truck
S13NewB
04-15-2007, 01:23 PM
I've had my 94 toyota pick up truck for a while now and i absolutely love it. the 22RE is the definition of a reliable motor. however, i may no longer have to use my truck as my daily driver, so i'd like to do a badass engine swap to make it an offroad monster. I believe the LS1 would be the perfect choice:
1. all aluminum lightwieght (maintain weight dist)
2. readily available powertrain for a good price
2. easy 400 hp with a cam/valvetrain upgrade
3. Torque monster!!!!
I'm curious to see if anyone knows of a shop, or forum where i can find someone who has dome something similar. I know that i can get the engine/ecu/harness, and custom mounts/headers. however i cant find any aftermarket support for a transmission conversion piece, or if there is an aftermarket transmission that will work with an LS1. any help would be awesome. thanks.
quicsilvia
04-15-2007, 01:31 PM
that would be sick
speedy02
04-15-2007, 08:00 PM
Here are a few good links to do research on how to do the conversion.
PerformanceTrucks.net Forums - powered by vBulletin (http://www.performancetrucks.net/forums/)
LS1TECH - LS1 Camaro, Corvette, Firebird, GTO, and Truck Tech! (http://www.ls1tech.com/forums/)
dsmcivic
04-27-2007, 10:12 PM
wow i wanna do that with my tundra. but you took it lol.
pinellas50
05-25-2007, 11:37 PM
www.v8s10.org (http://www.v8s10.org/)
DEATH ZEPPELIN
05-26-2007, 01:30 AM
with my 89 i was able to use a 350, just had to do a body lift to clear the motor. but it bolts right up to the toyota transmission and transfer case. if you wanted to go that route, its not that hard. I dont know how the ls1 would be, but would be pretty sick.
Mars_302
05-26-2007, 12:27 PM
Are you really that worried about weight distrubtion? You will be spending around $2k just for a motorset. You can go a lot cheaper getting a truck motor. They are same cept the trucks are iron block.
Hondaman7000
06-12-2007, 10:38 PM
ill buy your 22 re off you lmk pm me
CanTheWhales
06-13-2007, 08:42 AM
It's already nose-heavy...(just they way it is) and with an empty bed, much more motor and the back won't have any traction... but I see where you're coming from... also the 350 swap isn't popular, but is done quit often, but If you're going for power; though the stock drivetrain will mate up, it may not handle all that you wnat to put through it... there, that was way too long, but I hope this helps.....
Sneakin Deacon
06-16-2007, 01:45 AM
i think he meant the 5.3's, not the gen 1 350's.
speedy02
06-17-2007, 06:57 PM
You can find complete 5.3 at some junk yards for under $1000.
B18C14
07-09-2007, 03:35 PM
CALL HOYT AUTOMOTIVE, That is what he specializes in. He has a jeep with a LS1 in it with dana 60's front and rear for $13500. But he does several of these LS1 swaps and he is located behind McDonalds on US19 and 70th ave in St.Pete.
the guy @ discount on Bloomingdale is doing a LS1 in a HardBody Nissan...
Powered by vBulletin® Version 4.1.4 Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
Content Relevant URLs by
vBSEO 3.6.0
