View Full Version : Not audio...Light problem...Help Please!!
TpaS13
04-11-2007, 11:08 PM
Alright, so i get polled over 2 days ago at night for not having my running lights working....thankfully no ticket...
well the fuse blew for some reason and i tried today to figure out what was wrong,soo im thinkin maybe my trailer hitch box came undone and is grounding out a wire....nope... not that...pulled bulbs and checked them, all where good....it takes a 10 amp fuse so i tried bigger and went with a 12,15,20 then 30....all poped (except the 30) within 2 secs of the lights being on....when i turn on the lights all work but no running lights...when i press the break they turn on...my hazards turn on as well and so do my reverse light when i select all of them...... when i put the 30 in the low end of the top bulb(you know the top bulb that has a high and low light in it like a headlight bulb)lit up a little....i didnt want to run it for more than a few secs....anyways any ideas would help
thx
Rob
GradeA_TireFryer
04-12-2007, 09:35 AM
check the wiring behind the radio, does your dimmer lights work?
TpaS13
04-12-2007, 03:35 PM
you mean the gauge lights??? if so no they dont
GradeA_TireFryer
04-12-2007, 03:48 PM
i bet you have hooked up the gauge/dimmer light to ground behind the radio, it will test as ground until you turn lights on, try that and report back
this is a fairly simple troubleshoot even though i think gradeA has this one down, i feel its the same thing. Did you add any extra lights to any of your existing wiring? neons or foglights?
DEMON R13
04-12-2007, 07:21 PM
other than the new headlights, no he didnt....and last time i checked rob u didnt put the KC lightbar on either.....
cool. I dont see how the KC lightbar would do it either (unless he tapped directly into the line which would be retarded, and i know he isn't).
Truly is a pickle. Good luck with the search though.
btw i just gave you rep back and brought you from red to 3 green bars rofl.
the727kid
04-12-2007, 10:24 PM
You got pulled over for your DRLs?
his running brake lights at night. Yeh you can get pulled over for that, you need to have them active at night and i believe in heavy rain/fog.
the727kid
04-12-2007, 10:30 PM
Oooo brake lights I thought he meant like DRL headlights
TpaS13
04-12-2007, 11:35 PM
i believe i get what you are saying...but a little more detail would help me clear things up a bit.....if you are saying that the wiring for the radio is hardwired it isnt.....i used the smart harnesses from CCity and its all plug and play...if that help any....i could just be thinkin somthing different...
Ray- you wanna help me put those damn KC lights on tomarrow i got the relays for em now...
Rob
DEMON R13
04-14-2007, 05:31 PM
PO57-- LMAO!, thanks man
TpaS13--u lazy bastard do em yourself, everytime i ask u to do something u get distracted to easily, like with jello-shots......
By the way I figured out the solution to this problem after doing some, well ALOT, of research................Get a new damn car, rob!!!!, goddamnit!
Sincerely,
Demon
TpaS13
04-15-2007, 01:37 AM
TpaS13--u get distracted to easily, like with jello-shots......
ok i made the jello shots 1 time while we where doing somthing....oh and if i get a new car its not gonna be a jeep.....i want a truck or a cop car
Get ready to get your crown vic smashed its headlights/taillights out, scratch up hood/glass, or get keyed.
Oh and the infamous "fuk da po-lis" written with chalk/spraypaint on your driveway.
I'd love a black or straight up cop crown vic just because they're like a tank and comfortable as hell.
Content Relevant URLs by
vBSEO 3.2.0 RC5
