View Full Version : how to body prep
Jonas
04-11-2007, 12:31 PM
does anyone have any good links or any info they would like to add to this thread for inhome painters??
i found a few links online but it seems like they leave out some information and details.
any passages anyone cares to share?
sand paper grits, buffing, and other body prep info? thanks in advance
killerMikeD
04-11-2007, 11:56 PM
as in , fixing dents, panel replacement? or for paint? or for already clear coated applications lol.
CBURKE
04-12-2007, 04:56 PM
Auto Body and Paint Tips, Techniques, and Information (http://www.autobody101.com/forums/index.php)
Jonas
04-12-2007, 11:55 PM
basically, i have already primered the car. looks smooth, but i want it close to perfect as possible, i have a few spots i need to smoothen out.
how much of the actual first layer of primer shouldi sand off? and with what grits? afterwards, can i apply base paint or do i need to apply another layer of primer and leave it then base paint?? the current layer is pretty thick.
jlmaxima4sale
04-13-2007, 12:16 AM
what kind of primer because you might have screwed yourself if you went and bought that duplicolor crap if you want to use any descent paint alot of times those primers can cause problems with the good paint systems like PPG sikkens and dupont suck as lifting or wrinkling or even worse shrinking and creating primer lines where you had bondo and primed over it best thing to do if you used the duplicolor crap is sand as much of it off as possiable with 320 grit or 400 good clean way is by hand water sanding.... then go to a paint store like American Icon and get some K36 primer by ppg it doesnt react as bad as other primers would with duplicolor and put 2 medium coats on the car mixed 5:1 with k201 hardner then prep as you would for paint mix the same k36 4:2:2:1 with 4 parts k36 2 parts DMD base 2 Parts global reducer 1 part dx61 hardner that is the mix for the sealer covers sand scrathces real well and the primer is good cause once it sets it doesnt shrink use the sealer wet on wet meaning apply your base after a 10-15 min flash time need any other advice PM me ppg is good paint i can get away with using a littl under 3 quarts on a normal sized car where as u might need 5-6 quarts with some of the colors on dupont and PPG clear is awsome about the same price as the dupont chromaclear if you want american icon number text me 813-843-0600 and if you tell them i sent you they will probably give you a discount they have for everyone ive sent to them i think the paint generally run about 69-75 a quart depending on the mix and solid colors a bit cheaper hope this helps
GSR_CRX
04-14-2007, 09:44 AM
hey jlmaxima4sale (http://www.tamparacing.com/forums/member.php?u=32195),...wanna paint my car? lol PM me i'll pay you vbmenu_register("postmenu_4085724", true);
Clifford
04-16-2007, 05:30 PM
Ill help you out. Just get at me on AIM and ask me any questions. I just don't feel like typing everything I had to do. If I did then it would take me just as long to type as it did to do...you know how long that was haha.
Content Relevant URLs by
vBSEO 3.2.0 RC5
