PDA
View Full Version : 240 head unit instal help
Croba_Killa
04-05-2007, 09:44 PM
dose any one know what color wires go to the frount two sp???
Croba_Killa
95 -240 non se
POST
04-05-2007, 09:51 PM
try this out
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
the yellows and browns are speakers wires, take a AA battery and test two wires at the time
:D
Lookin2GoFA$T
04-05-2007, 09:55 PM
what song does an AA battery play? seriously, i don't follow you here.
POST
04-05-2007, 10:07 PM
... Its used to pop the speaker wires, that way you know what wire is for each speaker.... its a trick notladstyle showed me(i'm not saying he invented it).
That way in case if he decided to run new speaker wire or the wire doesn't look right or whatever reason it is, he can find out which speaker is which.
Croba_Killa
04-05-2007, 10:49 PM
thank you should have it know
POST
04-05-2007, 11:11 PM
TBSpyder
04-06-2007, 01:20 PM
Not the brightest crayon in the box are you.... :roll:
Notladstyle
04-06-2007, 01:40 PM
hes short bus yellow.
RickitySlick
04-06-2007, 02:40 PM
i learned that trick when i was working at soundadvice
Notladstyle
04-06-2007, 02:51 PM
i learned that trick when i was like 7
POST
04-06-2007, 03:00 PM
I learned that trick when i was 19 =[
Croba_Killa
04-07-2007, 07:37 PM
well that trick does not work when you have a built in amp from Nissan but does any one know what wires control the amp?? just wondering and also does any one know how to fix amps i have a 1200 Wat lanzar vibe needs fixing and a 800 wat kicker needs power terminal solder
Notladstyle
04-07-2007, 07:41 PM
It does with with the stock amp - listen VERY closely for a small pop, then turn the battery around and you will hear it again - every time you reverse the polarity.
Power terminal solder is no problem depending on the damage to the board.
The lanzar isn't worth fixing :crack:
POST
04-07-2007, 08:10 PM
dump the lanzar, if you still want stock amps and if you think yours are broken, i still have two that i can sell to you for 5 bucks each.
Croba_Killa
04-07-2007, 09:34 PM
well i belive the stock amp is fine i just have to hook it back up and the lanzar work great for me till i was solen i got it back and every time i hook it up somthing inside pops so o well i mite just say fuck it i also have 2 auidobahns 12005q and i can get a hold of two auiodobahn amps 800 wats a peice going to put in the car what do yall think about that set up for subs?
POST
04-07-2007, 09:58 PM
sounds like you're cheap
Croba_Killa
04-08-2007, 12:48 PM
yea pretty much lol
