View Full Version : need a little help
SkwervE
03-30-2007, 11:17 PM
i've got everything hooked up and when i turn the volume up the sub will cut out like distorting the bass and then cut back on and then cut back off.. it only does it when i have the volume up though.. it's been years since i've fucked with any systems so i have no idea what it could be..
Check if you have the gains set too high.
There are toooo many different factors. Mainly try that first, get them low as you can. if you can't hear anything having them that low its because the amp is too weak for the subs. Get a stronger amp.
also check grounds., make sure you have a SOLID ground connection and the ground is equal beefiness as power
joebobclark
03-31-2007, 01:01 AM
Sounds like protection mode. What amp? What subs? How are you subs wired to the amp (series, parallel)? Sounds like the ohm load is dropping to low and sending the amp into protection.
yeah its definitely protection mode, but given the fact that he says it only happens when he turns it up kinda rules out the Ohm load factor..... unless he had it at a ridiculously low ohmmage and the amp was overheating quickly (but wouldn't explain the volume = drop)
I'm feeling its his grounds.
Notladstyle
03-31-2007, 10:19 AM
low ohms will send it into protect if it pulls a lot of power.
the727kid
03-31-2007, 10:45 AM
x2, you can run a lot of amps at too low of an ohm load at low volume. More info would be helpful here though, VC Config of the sub, describe how it is wired. What size power and ground, what kind of amp.
But you talk of distorting bass, I would say set your gains properly. JL Audio's website has a good tutorial on how to set the gains.
you can run at too low of an ohm load at low volumes? shit i didn't know that, I was always told that the amp would see the resistance as too low and throw into protect mode automatically.
Cool.:D
GradeA_TireFryer
03-31-2007, 12:11 PM
maybe there kicker subs - and as they get older there spider gets sloppy
when he turns it up the cone flaps uncontroled and the voice coil leads are shorting out !
Notladstyle
03-31-2007, 02:06 PM
so far from chatting with him we have established the following:
Its a 4channel amp
He has 8ga power and ground
Only two channels are in use to drive a dual 4ohm sub
From this im betting that the sub is wired to 2ohms and that is the problem.
Its a 4channel amp
bridged really only accepts 4 ohms doesn't it?
I really wanted to do this with my audiobahns and the phoenix gold, when i came across this roadblock..
the727kid
03-31-2007, 04:21 PM
Most amps bridged only accept 4ohm loads, so I'm guessing that is the problem. 4gauge ground (or 0 if it accepts) and power wouldn't hurt either.
Notladstyle
03-31-2007, 06:48 PM
that amp wouldnt even make use of 8ohm - its a <600w amp.
BlackIceC4
03-31-2007, 10:24 PM
Is this a dual voice coil sub? How do you have the 4 channels hooked up? Are the subs in parallel, series, or separate channels? Your best bet to make sure things are hooked up right is to first take two leads off at a time and put an ohmmeter up to them.
Notladstyle
03-31-2007, 10:49 PM
we already solved it - the sub was wired to 2ohms. rather than dick with 4ohm bridged to the amp i just told him to wire it to 8 - he says its working great.
BlackIceC4
03-31-2007, 10:55 PM
Been there before. Glad it works!
SkwervE
04-01-2007, 12:15 AM
yea its perfect now.. thanks again man!
Content Relevant URLs by
vBSEO 3.2.0 RC5
