PDA
View Full Version : amp 4 sale
90gtjeff
03-22-2007, 10:58 PM
mtx 1200 watt amp. 2 channel. class d-----150 bux O.B.O.
no reasonable offer refused. need to get rid off this weekend--thunder series---part # ta3401
90gtjeff
03-23-2007, 12:13 AM
someone here has to have the need to put this thing to use.
Turbo3tc
03-23-2007, 12:27 AM
any problems with it?
90gtjeff
03-23-2007, 07:28 PM
no problems. i used to have a w7 12 sub and it pushed it like nothing. its pretty badass. need it gone fast!!!!!!!!!!!!!!!!!!!!!!! 130 bux!!!!!!!!!
90gtjeff
03-23-2007, 11:29 PM
bizump like this amp
90gtjeff
03-24-2007, 02:01 PM
100 bux!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
chondacrx
03-25-2007, 12:05 PM
i would be all over this if it was a 1200 watt amp... the amp is only rated at 400 watts
90gtjeff
03-25-2007, 12:55 PM
not when i bought it bro
90gtjeff
03-25-2007, 12:56 PM
its 1200 watt peak
90gtjeff
03-25-2007, 12:57 PM
the w7 i had was 1100 watt, and it pushed it like nothing, didnt heat up or nothing.
90gtjeff
03-25-2007, 10:54 PM
TittiesTittiesTitties------------75 bux
TpaS13
03-25-2007, 11:42 PM
holy crap...thats cheap....i sell these things all day at CC and there a pretty niice amp... to help sell it u might wanna put all the specs...go to cc.com
ITPete
03-26-2007, 07:14 AM
Is this a 1200 watt amp or 200 to 400? I might be interested, I just want to be sure I'm looking at the same thing and need to check my subs.
90gtjeff
03-26-2007, 02:14 PM
its 1200 watt peak. if it was a 400 and i had a 1100 watt sub hooked up to, i think it would have burned up. go to circuit city or best buy.com, and check it out
1stGen7
03-26-2007, 04:51 PM
Buy the Refurbished MTX Thunder Mono Block Amplifier (TA3401R) and other Car Amplifiers at circuitcity.com (http://www.circuitcity.com/ssm/Refurbished-MTX-Thunder-Mono-Block-Amplifier-TA3401R/sem/rpsm/oid/159667/rpem/ccd/productDetail.do)
200 watts RMS , 200 watts at 4 ohms and 400 watt and 2 ohms!
90gtjeff
03-27-2007, 08:56 PM
well u tried, not ta3401R------ONCE AGAIN---TA3401(NOT TYPE R)
Green_Streak
03-28-2007, 12:15 PM
hmm, doesn't seem like the R makes much of a difference does it? (http://www.cardomain.com/item/MTXTA3401)
still 200W @ 4 ohm rating
just because you run your amp on a 1200 watt sub doesn't make your amp a 1200 watt amp. sorry to pop your bubble
ITPete
03-28-2007, 01:12 PM
Exactly. And I think the "R" on the circuit city web site is for the "R"efurbished model.
90gtjeff
03-28-2007, 08:46 PM
sale pending. and for the record its not "R"efurbished
TpaS13
03-28-2007, 11:10 PM
Car Audio Amplifiers - TA3401 (http://www.mtx.com/caraudio/products/amplifiers/thunder3401.cfm)
that should end all this....
P057
03-28-2007, 11:37 PM
peak doesn't mean shit.
Burned up!? no. It would probably damage the sub if you were running all the gains on max and trying to turn the volume too high.
90gtjeff
03-29-2007, 08:49 PM
once again, sale pending.
TpaS13
03-29-2007, 11:49 PM
OK so to set this one straight....R IS for referbished...trust me i work at CCity...
its a good amp just not alot of power...and he not asking alot at all for it...G/L on the sale man
tphitterlude92
03-31-2007, 02:54 PM
where are you located? very interested and could buy this weekend!!
Destrukt
04-01-2007, 04:05 AM
ill buy ifu drive to me, pm me with answer and link to thread so i know what ur talkin bout
