bigmike1
03-18-2007, 02:43 PM
like it says i got the bentley of autometer tachs
info: from summitracing.com
autometer pro comp g3 playback digital analog tac with external shift light...$150 firm
heres link to it. specs, instructions,good picture of it new
Auto Meter Pro-Comp Playback Tachometers: ATM-6864 - summitracing.com (http://store.summitracing.com/partdetail.asp?part=atm-6864)
heres pictures of it
http://i43.photobucket.com/albums/e3...Picture053.jpg (http://i43.photobucket.com/albums/e354/bigmike8906/Picture053.jpg)
http://i43.photobucket.com/albums/e3...Picture054.jpg (http://i43.photobucket.com/albums/e354/bigmike8906/Picture054.jpg)
heres picture of what it looks like lit up so you can see the digital part (pic from summit racing)
http://i43.photobucket.com/albums/e3...6/atm-6864.jpg (http://i43.photobucket.com/albums/e354/bigmike8906/atm-6864.jpg)
part# atm-6864
msrp $329.95
brand: autometer
techometer usage: standard
gauge series: analog
gauge range: 0-9000 rmps
gauge diameter(in): 5"
sweep: full sweep
techometer installation: universal
gauge face color: black
gauge number color: white
pointer color: red
bezel color: silver
rev limiter: no
memory recall: yes
playback: yes
oem replacement: no
sending unit: electrical
footnotes: 7-4 stage shift light 1-operates on 4,6,8 cylinder engines with points,electric,and most 12volt preformance racing ignitions.
autometer pro comp playback techometers allow you to record and playback engine rpm for each of your runs at a rate of 50 samples per second. the playback process will reveal important tuning information,including engine rpm at each shift point,rpm at the end of a run, and any tire to clutch slippage. passes can also be printed out on a dot matrix printer using autometer's printer interface.
part# atm-6864
msrp $329.95
brand: autometer
sweep: full sweep
pointer color: red
bezel color: silver
rev limiter: no
memory recall: yes
playback: yes
oem replacement: no
