Mr Takara
03-16-2007, 02:04 AM
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153985.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153985.jpg)
s14 5 lug spare tire $15 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153984.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153984.jpg)
s13 sr20 coil packs with harness from running sr $50 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153983.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153983.jpg)
s13 sr20 coil packs (top view)
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153982.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153982.jpg)
60 gallon Husky Air Compressor (stand up type) $600 O.B.O comes with everything including hoses and fittings.
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153981.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153981.jpg)
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153980-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153980-1.jpg)
2jz full motorset AT from sc300 (engine, tranny, ecu, full harness, new timing belt in box) $200 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153979-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153979-1.jpg)
pic 2 of 2jz
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153973-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153973-1.jpg)
pipe bender for custom exhaust/intercooler piping
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153970-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153970-1.jpg)
pic2 of pipe bender
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153967-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153967-1.jpg)
s13 se (2) rims and (1) 180sx mesh rim original
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153964-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153964-1.jpg)
180sx mesh rim
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153961-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153961-1.jpg)
RB25 fast spooling turbo/exhaust manifold assembly with stock oil and coolant lines/heat shield. No shaft play/no black smoke. $200 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153959-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153959-1.jpg)
pic 2 RB25 turbo with internal wastegate
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153955-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153955-1.jpg)
pic 3 RB25 set up complete with downpipe 6 bolt flange (rare only to skyline)
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153952-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153952-1.jpg)
sc300 reinforcement bar $25 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153950-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153950-1.jpg)
95 eclipse gs-t side mount intercooler $50 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153946-2.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153946-2.jpg)
RB25 throttle body with tps/diag port $20 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153943-1.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153943-1.jpg)
10.5cm dia silencer. Would fit N1 $10 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153925.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153925.jpg)
s14 front calipers with 35k miles on. Comes with pair with brake pads with more than 90% life left $60 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153940.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153940.jpg)
pic 2 s14 front brake pads
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153937.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153937.jpg)
95 gs-t eclipse turbo w/wastegate $75 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153934.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153934.jpg)
s14 Master Brake Cylinder from s14. No cracks in container with clip ABS $30 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153931.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153931.jpg)
sr20 stock downpipe with heat shield intact $30 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153928.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153928.jpg)
Misc intercooler piping for sr $1/ headlight braket for s13 $1, misc spacers $1
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153922.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153922.jpg)
RB25det recirculating valve/ intake pipe $20 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153920.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153920.jpg)
49cc Jet moto mini bike exhaust brand new $35 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153917.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153917.jpg)
pic 2 of mini bike exhaust
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153914.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153914.jpg)
sc300 original carbon canister $10 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153907.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153907.jpg)
s14 Open diff 6 bolt perfect for having welded for drift. $60 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153905.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153905.jpg)
1jz side mount intercooler with duct $75 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153899.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153899.jpg)
225/45/18 potenza tire may need simple tire patch. Plenty of thread left 80% $15 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153896.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153896.jpg)
205/55/16 drift tire (2) $10
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153892.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153892.jpg)
s13 tear drop Nissan rims (2) w tires $30
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153889.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153889.jpg)
pic 2 of s13 rim
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153886.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153886.jpg)
sc300 with emblem and shock absorber $75 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153883.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153883.jpg)
pic 2 of sc300 rear bumper with emblem
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153880.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153880.jpg)
damaged fender $10 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153877.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153877.jpg)
95 Eclipse gs-t bumper $35 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153874.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153874.jpg)
s13 rear stock bumper w/absorber . No damage $50 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153871.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153871.jpg)
sc300 plastic under cover $5
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153868.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153868.jpg)
1jz ac compressor $35 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153865.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153865.jpg)
pic 2 of ac compressor for 1jz will fit 2jz
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153862.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153862.jpg)
Universal oil cooler w/ sandwich plate for Nissan $35 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153856.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153856.jpg)
sc300 5 lug rim $30 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153854.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153854.jpg)
Sc300 bumper with with foglights $75 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153850.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153850.jpg)
pic 2 sc300 front bumper with foglights
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153844.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153844.jpg)
wrx 03’ bugeye side skirts great for painting or leaving stock $35 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153838.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153838.jpg)
z32 outer axles 5 bolt. 1 perfect condition 1 needing new boot. $40 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153835.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153835.jpg)
pic 2 z32 axle
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153832.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153832.jpg)
Z32 VLSD 5 Bolt w/ s13 rear cover already attached. Great for rebuild $70 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153830.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153830.jpg)
pic 2 Z32 VLSD
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153826.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153826.jpg)
pic 3 Z32 vlsd
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153823.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153823.jpg)
s14 rear outer axles. Perfect condition boots still intact $40 O.B.O
http://i154.photobucket.com/albums/s247/reason_ili/th_P3153820.jpg (http://i154.photobucket.com/albums/s247/reason_ili/P3153820.jpg)
pic 2 s14 rear outer axles.
pic 2 of 2jz
pic2 of pipe bender
180sx mesh rim
pic 2 of s13 rim
pic 2 z32 axle
pic 2 Z32 VLSD
pic 3 Z32 vlsd
