marKs
03-01-2007, 04:30 PM
hey guys,
i have a 16v 4ag corolla gts converted. ive got the car running and idling decently...it still bumps around 800-1200 rpms occasionally because i need to time the dizzy and tinker with the TPS. so, the car idles fine. here's the problem:
the car WILL NOT rev. it's like my AFM is completely not there, but it is...or its like i have a gigantron vacuum leak, but i dont. when i tap the throttle, itll just blip to about 3,500 ish, then go back to idle...even if im holding down the throttle.
here's some background:
KA24DE fuel pump & new fuel filter
SR5 gas tank w/ replaced lines
starts up awesome
no check engine light when the car is on
full coolant...small leak on the coolant inlet in the throttlebody because i ran out of clamps
blocked EGR
and im out of things to tell you.
gimme some suggestions
starts up awesome
blocked EGR
