View Full Version : boostin problems........
SLEEPIN_92SE-R
02-28-2007, 01:00 AM
:( hey guys i have a 03 srt4 recently i have been having problems with the vaccum hoses popping off and i have zip tied all of them back to the original locations but now the car would not boost past 8 psi... Help Please
You've done a leak test on the entire system?
If yes, how does the car run overall at 8PSi?
smoothblacksrt
02-28-2007, 09:25 AM
My friend had the same problem with his srt4. We found out that the air inlet temp. sensor had popped out of his cold pipe. Just something to check.
SLEEPIN_92SE-R
02-28-2007, 10:41 AM
no i have not done a boost leak test...... who can do that for me....i will check that sensor out.... thanks......... at 8 psi is slow as dirt
Boost leak....since I dont feel like typing out :) , check srtforums in the how to.
It shouldn't cost ya more than $10 for a basic one.
SLEEPIN_92SE-R
02-28-2007, 11:56 AM
true now i got a question when my car was popping the hoses off the check engine light ;came on and reads multiple misfires so now i got a msd coil pack and wires and some spark plugs you think that wil help out the problem
Oh multiple misfires....I would have said plugs n wires. I had a similar problem on my s3. I couldnt get over 15PSI. Turned out that my MSD wires died after 40K.
SLEEPIN_92SE-R
03-01-2007, 01:52 PM
well guys i changed the plugs and now its good just waitin on the wires and coil does the msd setup make a difference thanks cali
smoothblacksrt
03-01-2007, 10:09 PM
I heard pretty much nothing but complaints about the msd coil. My friends msd coil went out in about 5k miles. Crane makes a coil you might want to consider getting it.
I've head bad things about the MSD pack. I never used it. I just had the wires.
They died after 40K miles, but it was a tough life for them, so its hard for me to classify them as junk.
SLEEPIN_92SE-R
03-02-2007, 01:58 PM
well i will just hold off and save my money and do something else to make it faster wqat can i do affordable and worth doing
smoothblacksrt
03-02-2007, 07:58 PM
What do you have done to the car so far?
SLEEPIN_92SE-R
03-04-2007, 01:28 AM
nothing jus the mopar bov, tein stech springs, and nothing done to the motor hopefully sunday my boy is going to do the boost leak test and then i am not sure wat to do next
Content Relevant URLs by
vBSEO 3.2.0 RC5
