High Performance Oil Pump
Old Feb 27, 2007 | 08:07 AM
streetfusionracing's Avatar
StreetFusionRacing.net
Default High Performance Oil Pump
I was wanting to know if anyone my know some manufacturers or somewhere I could get a oil pump that is better than stock for the
b series engine.
Old Feb 27, 2007 | 08:13 AM
99B16Si's Avatar
just use a stock one, there is absolutely no reason to "upgrade" your oil pump. the only thing that can really be done to the oil pump is put a shim under the sprung release valve to build slightly higher pressure or u can replace the gear inside with a supossedly "hardened" gear whic is less likely to shatter due to excessive vibrations
for what reason do u think u need to upgrade this???
Old Feb 27, 2007 | 10:10 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
Ive personally seen some 800+ whp cars, and heard of some 900+whp cars, that use stock, unmodified ITR oil pumps...At least one of which is turning over 11k RPM... No shims, no gear, no nothing... Straight from the dealer stock...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Feb 27, 2007 | 10:51 AM
KJ's Avatar
KJ
bored at work
Wouldn't be a bad idea to cryo the gear and rotor. If I was going to do a 600+ car I would.
Old Mar 1, 2007 | 02:09 AM
Depending on the design, some pumps can be fabbed to have wider gears
by welding 2 sets together, and cutting up another oil pump body
to make a spacer that will "lengthen" the pump by the same amount,
with longer (by the same amount), mounting bolts.-Bob
Old Mar 1, 2007 | 06:26 AM
MrLHT's Avatar
John @ LHT Performance
The Stock Honda pump is fine to 600+ that I have used.I use the stock ITR one also.
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
Old Apr 2, 2014 | 03:01 PM
What kind of pump have you used?
