View Full Version : DVC sub wiring?
ShakinIt
01-28-2007, 08:06 PM
Ok, I've got two Kicker 10" Dual 4-ohm Voice Coil subs and a Kicker 750 watt mono sub amp. I'm wondering what the best way to wire these would be? I've never wired DVC subs before.
Miles
01-28-2007, 08:28 PM
is that amp 1 ohm stable?
the727kid
01-28-2007, 09:49 PM
dual 4 = 1ohm :)
kpr10is
01-28-2007, 11:52 PM
Assuming its a Kicker ZX, because iirc the KX series was a 600.1 not 750, its only 2 ohm stable. Which means youre kinda fucked. You can either run your amp at 4 ohms with both subs, or ditch one sub and run 750 watts to just one, both being somewhat shitty options. Best options being to return the subs for dual 2 ohm ones, or get a 1 ohm stable amp.
+1
ShakinIt
01-29-2007, 09:23 PM
returning the 4ohms, getting dual 2's....
guess I shoulda researched BEFORE I bought them...:roll:
thanks for the help
GradeA_TireFryer
01-30-2007, 08:57 AM
With The 2 Dual 2 Ohm Subs - Wire 2 Vc On Each Sub In Series And Then The 2 Subs In Parrell - 2 Ohm Load - Your Amp Will Be Happy,
ShakinIt
01-30-2007, 08:46 PM
Got two dual 2 ohm L7s hooked up and hitting nicely. Thanks again for the help!
Content Relevant URLs by
vBSEO 3.2.0 RC5
