View Full Version : HELP ASAP...97 Camry...
Skittle
01-23-2007, 06:59 PM
The wires are all different colors..
I got the Switched 12v+ figured,and the ground figured.
It's saying th econstant 12v+ is a blue/yellow wire...And there is no blue/yellow wire. :dunno:
The harness did'nt include a dimmer or illumination wire either.
Help me asap,The wife is getting tired. :lol:
Rep for those who return answers. :-)
Thanks fellas.
Thanks fellas.
some cars do not have the dimmer wire.... mine didnt =S
the 12v should be yellow or red sometimes i think... i'll wait till dalton chimes in, he'll know more about skittles than i ever will haha
if you can take pics that'd help tremendously.
Skittle
01-23-2007, 07:05 PM
It's a 97' Camry. :lol: Not a Skittle.
I'm not to worried about the dimmer wire,Mainly the Constant 12V+.
I got a diagram readout,But it says that the constant 12v+ is a blue/yellow wire..Then it says the reg. blue wire is the Right Front (-) and the plain yellow wire is th Left Rear (-)...
Grrrrrrrrrrrrr...
Grrrrrrrrrrrrr...
oh teehee.
It should be a wire thats slightly beefier than most the other ones.... like i said, take a pic!
Stuff your hand in there and try to pull forward as many wires as you can.
TBSpyder
01-23-2007, 07:17 PM
Doesn't sound like exactly the best way to do things, but it'd be fun to watch. :lol:
Skittle
01-23-2007, 07:23 PM
Pics up in a second.
Skittle
01-23-2007, 07:28 PM
I've done over 20 CD players..And this is a first. :lol:
http://i24.photobucket.com/albums/c46/SkittleTR/DSC00790.jpg
Here's a written diagram I got.
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Dark Green
Dimmer White/Green
Antenna Trigger n/a
Antenna Rear Window
Front Speakers 6 1/2" Doors
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
Notladstyle
01-23-2007, 07:57 PM
forget those wires, it will take less time to tap the ignition harness for the power/acc, run a new ground, and run speaker wires than to figure out wtf that chopped up harness if it doesn't match the diagram.
GradeA_TireFryer
01-23-2007, 08:17 PM
old school cut the harness- 5 minutes and i would have it working $20.00
Yeah i have a fear of touching bare metal but sometimes i can just stuff my hand in my dash and just tug at things.... hahahahahah
hOLY Christoph!
what the hell is that spaghetti fuck!?
do what dalton says yo....... do ....something...... Ahhhh!
:puke:
nofxareforkids
01-23-2007, 10:03 PM
constant SHOULD be blue/yellow, but you're right, its not there, if you have a multimeter, go through each wire and figure out which is constant, the thicker guage solid brown wire will be ground, it is on all toyota's. thats about the best advice i can give, o and make sure your underhood fuse is a-ok
TBSpyder
01-23-2007, 11:20 PM
Very good point. With the harness looking like that, the constant could have very well blown the fuse.
Skittle
01-24-2007, 12:31 PM
Yea I know the ground is brown...Still have'nt figured out the constant,I got a multimeter,Gotta go dig it out though..
Anyone else?
Notladstyle
01-24-2007, 12:39 PM
a day later and u still havent tapped the ignition wires? you could be done in 15 minutes with a few T-taps and some electrical tape.
Skittle
01-24-2007, 12:42 PM
I'm not familiar with tapping the ignition..
TJElite
01-24-2007, 12:55 PM
Well, it looks like you have 14 wires, and the chart only lists 13...hmm...
Have you tried eliminating all the other colors, and see what's left? I've seen factory harnesses that, for whatever reason, sub'd a color.
A meter is still your best bet, and you could use it to confirm speaker leads (provided there is no amp), but at least this would narrow down the search.
Toby
Content Relevant URLs by
vBSEO 3.2.0 RC5
