flubyux2
01-23-2007, 03:47 AM
well after replacing my pressure transducer and governor solenoid, filter, and fluid, the truck ran great for a while. itd get out of the hole nicely and have positive upshifts and tc lockup. but after fixing one problem, i get another.
it now hunts for gears and the converter solenoid cycles on and off. so cruising down the freeway, the converter will unlock and lock back up, sometimes repeatedly, maybe 10 times within 30 seconds.
then, sometimes, w/o changing throttle position, it downshifts into 3rd and wont upshift. it stays in 3rd gear, doesnt lock up and does 50mph at about 2200.
and when it gets REALLY bad, ill take off from a stop in 1st gear and itll TRY to go into 2nd, but hunt back and forth before surging into the next gear. then itll do it again between 2nd and 3rd. it wont go into 4th gear though.
ive put the scan tool on there an watched the TC solenoid cycle on and off. my TPS voltage didnt spike though. neither did my trans temp or trans temp sensor voltage. my TPS doesnt seem to have any flat spots as i open and close the throttle when i watch it on the scanner.
the problem only seems to show up at night time. its usually problem free during the day. some people say its the alternator creating alot of electrical noise because of worn brushes? everyone says this is usually the cause of problems on the 24v trucks w/ the APPS. i saw a TSB for a hunting problem that pertained to the TC unlocking and locking, but im having problems w/ 2nd,3rd and 4th engagment too.
