Addison
01-19-2007, 12:14 PM
i have a JL Audio e6450 6 channel Amplifier with subwoofer componets, but the thing is the protection light comes on and i get a weird sound. i took it to the shop to get it fix the guy said it's simple and wouldn't cost that much. i don't have the money to get it fixed so i want to sell it but everyone tells me dont because of it being a JL Audio e6450 to wait and get the money for it is to good of an amp just to let go. make offers worth:$400.00 make me an offer
http://carsound.com/articles/uploads/jl_audio_02.jpghttp://carsound.com/articles/uploads/jl_audio_01.jpghttp://www.sonicelectronix.com/images/normal/e6450.jpg (http://www.sonicelectronix.com/viewitem.php?id=5972&affiliate=PriceGrabber#)
Product Information:
strong>"e" Series Amplifiers :</STRONG>
The value-packed e-series amplifiers feature the same patented Class D and Class A/B output technologies as the flagship "Slash" amplifiers. The primary difference is that "e-series" amplifiers employ a more conventional unregulated PWM switching power supply instead of the R.I.P.S. design used in the Slash models.
All e-series models are realistically rated at 12.5 volts DC supply and include flexible signal processing sections, differential-balanced inputs and solid, aluminum/steel chassis construction.
Rated Power 12.5 V Stereo:
45W RMS x 6 @ 6 x 4 ohm
75W RMS x 6 @ 6 x 2 ohm
Rated Power 12.5 V Bridged:
90W RMS x 3 @ 8 ohm
150W RMS x 3 @ 4 ohm
Rated Power 14.5 V Stereo:
70W RMS x 6 @ 6 x 4 ohm
110W RMS x 6 @ 6 x 2 ohm
Rated Power 14.5 V Bridged:
140W RMS x 3 @ 8 ohm
220W RMS x 3 @ 4 ohm
THD at Rated Power:
12.5V: <0.08% THD, 20 Hz - 20 kHz
14.4V: <1% THD, 20 Hz - 20 kHz
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz - 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm per ch. / 50 Hz,
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV - 8V RMS
Dimensions (L x W x H):
17.70 in. x 9.25 in. x 2.36 in.
450 mm x 235 mm x 60 mm
90W RMS x 3 @ 8 ohm
THD at Rated Power:
S/N Ratio:
Frequency Response:
Damping Factor:
Slew Rate:
± 22V/µs
Input Range:
200mV - 8V RMS
