Next Quiz Thread: Twin Turbos
What are the advantages and disadvantages of running parallel (non-sequential) twin turbos on the same cylinder bank?
I'm not a very good technical person when it comes down to it, but dosn't it have to do with having the car make more power without the turbo lag. So basically one turbo spools at low RPM, while the other spools at a higher RPM. It makes the cars more driveable from the factory, while still putting out bigger numbers than one smaller turbo.
It also depends on how many cylinders are in your "bank". Are we talking 1/2 of a V8 here? Does one I6 count as a bank? I also assume that you're talking about equal total flow between setups? (ie. 2x 25lb/min turbos versus 1x 50lb/min turbo)
There is incresed exhaust flow efficiency by having fewer runners per turbo. This is the idea behind twin-scroll technology. That is one thing going for a twin setup over one single-scroll turbo. The other idea I've heard tossed around is that twin smaller turbos have lower total inertia than a big single, which helps them spool faster (assuming both setups support equal flow). This argument was countered with accusations that the inertia difference only applied to older turbos, and that newer turbos are designed with a lot less inertia per flow.
only thing i could think of is that two would spool fast casue the each turbo only has to do half the work like instead of 20 psi on one turbo but 10 psi on each turbo but im probley wrong im not that great when it comes to shit like this but yes twice the headache
See what I'm sayin?
