PDA
View Full Version : Front suspension styles
Mars_302
01-11-2007, 11:03 PM
So im sorta wondering whats the better style of these 2 suspension styles.
The style on my mustang has the 1 control arm, and a macpherson strut. The control arm connects At 2 points to the k-member.
Then you have something like what a Nissan 240 has, with 1 control, 1 tension rod and a strut. The control arm is connect at only 1 point to the k member, then then tension rod is the 2nd pt .
Which is the better style?
mofugga
01-12-2007, 09:04 AM
i would say the nissan's is better cause it's not a ford but i'm not familiar with either suspensions so my opinion is really worthless.
treekiller
01-16-2007, 11:25 AM
just an added point of adjustability from what I can tell.
McPherson Struts are simple. work well (When tuned correctly) are are cheap to build. just keep in mind they do not forgive over lowering a car, nor do they forgive poor tuning.
PseudoRealityX
01-19-2007, 09:08 PM
The "style" suspension is not better than another. You'd have to look at the bump curves to see which particular setup is better.
