EclipseTurbo94
01-05-2007, 05:05 PM
Eclipse 2.0t 6 Bolt 4g63 Swap 4000 Miles On Fresh Motor, Amazing Car
Ok I Got A 1994 Mitsubish Eclipse Gst Fwd Great Car
RECIEPTS FOR EVERYTHING
GREAT RUNNING ,AWASOME FOR DAILY DRIVER
Fully Rebuilt Motor 4000 Original Miles On Fresh Motor
New
block
Pistons
Rods
Rod Bearings
Main Bearings
Rings
head
Valves
Valve Guides
Lifters
fuel
f I C 650 Cc Injectors
o Rings
seals
s A F C 1
walbro 255 Fuel Pump
new Fuel Filter
fuel Preasure Regulator
with Gauge
performance
big 16g Turbo
k.n. Air Filter
big Front Mount Measure. 32*12*28
2g Elbow
2g Manifold
stock Bov
2.5 Inch Exhaust
upgraded Fly Wheel
brand New Act 2100 Preasure Plate
act 6 Puck Unsprung Disk
new coil overs
new Parts
pads Front
front Rotors
oil Pump
water Pump
axles
master Cylinder
slave Cylinder
battery
cam Angle Sensor
timing Tensioner
balance Shaft Tensioner
seal All The Way Around
coolent Hoses
throttle Cable
gauges
oil-black Face Autometer
temp-silver Face Autometer
boost -black Face Autometer
air/fuel-silver Face Autometer
interior
mint 100%
full Black Racing Seats
- Made For Custom Engravings
powdercoated Silver Gst Wheels With Firestone Tire 75% Tread
front Drift Body Kit Bumper
altez Tail Lights
paint Job--flat Black With Clear Coated Moldings
im Alex - 4800 Obo No Lowballers
thank You 727-244-8277
New
block
Pistons
Rods
Rod Bearings
Main Bearings
Rings
head
Valves
Valve Guides
Lifters
fuel
o Rings
seals
s A F C 1
new Fuel Filter
with Gauge
performance
big 16g Turbo
k.n. Air Filter
2g Elbow
2g Manifold
stock Bov
2.5 Inch Exhaust
upgraded Fly Wheel
new coil overs
new Parts
pads Front
front Rotors
oil Pump
water Pump
axles
master Cylinder
slave Cylinder
battery
cam Angle Sensor
timing Tensioner
coolent Hoses
throttle Cable
gauges
interior
mint 100%
altez Tail Lights
