95firechicken
01-05-2007, 10:47 AM
i have 2 pairs. both pairs are new in bow, never been installed. $400 gets both pairs. post, pm or call. my cell is 813-244-4037 mike
here are the specs:
MB Quart PSD 216 speakers:
Sensitivity: 2.0 dB
RMS Power Range : 60-130 Watts
Peak Power Handling: 260 Watts
Frequency response: 38 - 32000 Hz
Diameter: 6.5 Inch
Features
Easy coaxial or separate tweeter mounting
Impedance: 4 Ohms
Frequency Response: 38 - 32,000Hz
Sensitivity: 2,0dB
Power Range: 60 -130 Watts
Crossover Frequency: 2.500Hz
Premium series midbass drivers:
Titanium WPC (wet powder coating) polypropylene cone
Solid metal phase plug and tweeter bridge inserts
1-piece composite ABS chassis
Injection molded magnet system
Overall midbass diameter: 6.54"
Premium series 1" (25mm) tweeters:
2-piece titanium domes
Composite surrounds
Metal housings
Neodymium magnets with ferrofluid cooling
Integrated diffusion lens
Tweeters can be coaxial or separate mounted
6-position coaxial tweeter angle adjustment
Flush and surface mounting hardware
Surface mounting hole diameter: 1.16"
Overall tweeter housing diameter: 1.38"
Premium series crossover networks
Balanced Temperature Technology (BTT)
4-level tweeter control
Optical tweeter protection using HPCCR (High Positive Current Coefficient Resistor)
Bi-amp and bi-wire capable
Gold-plated screw terminals
12 dB/octave crossover slopes at 2,500 Hz
Woofer grilles, coaxial tweeter bridges, and mounting hardware included
here are the specs:
Sensitivity: 2.0 dB
Diameter: 6.5 Inch
Features
Impedance: 4 Ohms
Sensitivity: 2,0dB
Composite surrounds
Metal housings
