Scott90
12-25-2006, 11:43 AM
hey guys, i bought 2 rampage ba-100 subs about 2 weeks ago, but just now opened them for christmas. just my luck, one of them is completly broken, the box is broke and the sub is just moving around freely in the box so that one is going to be sent back
so i have the one still and im trying to learn how to install it myself, i have a few ideas on how to do it, i just dont wanna screw up. here is what the instructions say...
well first, the box says its easy to hook up since the amp is built in the box already... but anywho, heres what it says....
WIRING
There are 4 connections necessary for proper operation of the BA-100.
1. 12 volt (12v): Connect this wire to a source of +12 volts which does not turn off with the ignition key. It may also be connected directly to the positive (+) terminal of the battery.
2. Ground (GND): secure this wire using a screw or bolt on a grounded metal surface of the vehicle. Clean away any rust, dirt, or paint from the surface to make sure a good connection is made.
3. Speaker input positive (SPK +): splice this wire to the wire going to the positive (+) terminal of the speaker that you have chosen (sometimes indicated by a red dot).
4. Speaker input negative (SPK -): splice this wire to the wire going to the negative (-) terminal of the speaker that you have chosen.
im so confused.... please help, someone tell me exactly what i have to do, but a much easier way.
WIRING
