need help please asap
Old Dec 23, 2006 | 06:03 AM
EclipseTurbo94's Avatar
Default need help please asap
ok here i smy prob car runs fine ok i take off in first slam 2nd boost level barly even moves whats wrong
turbo is fine checked it completely
but i ethier half to be in gear for a min then get on it but when ever i slam gears the boost level does not increase so i basicaly take the fuck off then slow the fuck down due to the car not boostin
car -1994 eclipse gst 6 bolt swap 5000 miles on motor new everything
any suggestions
Old Dec 23, 2006 | 07:43 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
did you check the wastegate?
SUCH IS THE RULE OF HONOUR.
Old Dec 23, 2006 | 10:30 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
yea possible put some washers on the wastegate mounting bracket to make it pull shut harder.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Dec 24, 2006 | 09:34 AM
internal wastgate
Old Dec 24, 2006 | 10:27 AM
yeah ok? so that means it never fails? internal gates fail the most.
Old Dec 24, 2006 | 03:38 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
yea we assumed you had an internal gate.... try putting washers on the mounting bracket it might work. worth a try
-Dane
98 240 w/ bolt-ons
Srqspeed.com
