PDA
View Full Version : LT1 water pump
GTman85
12-11-2006, 09:04 AM
How hard is it to replace a water pump in an LT1. Mine just went out this weekend this is the only thing i havent replaced on my car. Any tips that would make it easier on me?
formula69
12-11-2006, 09:16 AM
its easy call me if you need a walk thru ive done it more times than i can count.. 727-643-3876
dalinkwent05871
12-11-2006, 03:51 PM
yea its pretty simple.. had to do it twice myself...problem with mine was when water pump started leaking the distributor is right under it... ;(
GTman85
12-11-2006, 04:06 PM
My opti seems ok. Its leaking from underneath. The bottom part of the housing
formula69
12-11-2006, 04:51 PM
your opti is ok for now but it wont be if you arent careful with the water pump.. make sure the coolant is drained before you take the pump fixture off
myltwon
12-11-2006, 09:41 PM
sounds like coolant is coming out of the wheep hole, changing the water pump is cake, I'm guessing you already took off the air pump, if so it's even easier then
BPU95
12-11-2006, 11:38 PM
easiest thing to change on the car. don't worry about getting the opti a little wet cause it works fine once dried. you should just forego another mechanical pump and get an electric one. the Meziere is about $200 but well worth the money. your motor will run so cold that your fans would almost never have to come on. you will just have to know how to use a punch, hook up a relay and cut ever so slightly into the fan shroud. oh yea, while all the stuff is out you should take the time to clean off and lightly silicone around all the areas where water can leak into the opti. mine has gotten wet several times since then without misfiring.
Mars_302
12-12-2006, 12:51 AM
If you havent done the opti yet, id go ahead do it since you are good for another 75k+ miles
GTman85
12-12-2006, 09:21 AM
Id like to do the opti when i do the pump but since i dont have a dollar to spend at the moment, ill stick with just the pump. Ill be doing it this weekend.
myltwon
12-12-2006, 03:33 PM
do electrical then you can upgrade to a gen1 sbc timing chain
