speedofsound
12-04-2006, 02:27 PM
Two Alphasonik 15in subs in box
5 months old
Dual 4 ohm voice coils
800 RMS each
PSW615J
15” ALPHA 600 SERIES SUBWOOFER
Cast Aluminum Machine Cut “Alpha” Basket
Motor Assembly Heat Sink
Kevlar® Reinforced Composite Balanced & Laminated Cone
TLTF J-Surround
Flat Progressive Rate Nomex® Damper w/ Spiral-Woven Leads
8-Gauge Lug-Lock Input & Output Terminal
Rated at 800 Watts RMS
92dB Efficiency
Frequency Response of
25Hz to 500Hz
98 oz. Double-Stacked Magnet
Dual 4-ohm 2-1/2” Voice Coils
Mounting Dimensions
Depth: 7 1/2”
Through Hole: 13 7/8”
Diameter: 15 1/4”
$200 Firm
5 months old
800 RMS each
PSW615J
TLTF J-Surround
92dB Efficiency
25Hz to 500Hz
Mounting Dimensions
Depth: 7 1/2”
Diameter: 15 1/4”
$200 Firm
