hachibill
11-28-2006, 04:30 PM
thinking about another motor, so the 7m needs to go.
motor set includes: complete 87 7mgte(under 80k miles on motor) complete from oil pan to flywheel, harness, ecu, safc(already wired in and tuned), lexus maf, 550's, cometic HG, arp head bolts, ball bearing innovative turbo's 60-1 turbo, stainless oil and water feed lines, ported stock exhaust manifold, all accessories, intake tube, open 02 housing, 3inch hks down pipe, complete spearco intercooler kit with all piping, apexi BOV, hell i'll even throw in the stock radiator with perma cool fan and wiring.
many new oem toyota parts, including all hoses, plugs, wires, thermostat, all gaskets, timing belt. ect.
motor has been driven only a couple miles since the swap was completed. made 370hp, 330tq at 14psi at the rear wheels. turbo is good for about 25psi. should make over 400hp at 18psi.
basically you get everything except the clutch and tranny.
and i have tons of extra 7m parts that can go as well.
still in car running, can here it run before i pull it!!!!
asking $3500 obo
asking $3500 obo
