View Full Version : difference?
.Seth.
11-25-2006, 04:34 PM
OK well wats the difference between stock 2.0 cams and R/T cams?
Josiah
11-25-2006, 05:40 PM
if you are talking DOHC cams, there arent any, if you are talking SOHC cams, there is about 5hp worth
.Seth.
11-25-2006, 05:57 PM
alrite im talking DOHC so thanks
Josiah
11-25-2006, 06:40 PM
unless you are talking 420A cams(eclipse/avenger cams) they are 5hp weaker
.Seth.
11-25-2006, 06:44 PM
well wat motor is in the neon? i always thought it was the 420a
Josiah
11-26-2006, 09:14 AM
no, the neon is the D4RE or S4RE, depending on DOHC or SOHC
neondriver
11-26-2006, 11:06 AM
read up on this: Neon technical, review, and information site (http://www.allpar.com/neon/neon.html) it will give you alot of informations on different aspects of the neon. neons arent 420A i believe thats an eclipse code where the head is switched around(intake in rear). 420 is a comon misconception seeing 420=4 cylinder 2.0 L, sometimes it is alot easier to just say 420A because more people know it than the D4re that it is called
.Seth.
11-26-2006, 12:15 PM
^thanks! theres alot of info on that site and ive only read a little bit of it
Josiah
11-26-2006, 01:10 PM
allpar is the bomb, its THE chrysler site...tons of info on T1,T2,T3 cars...strange special editions, plus the old musclecars too
Content Relevant URLs by
vBSEO 3.2.0 RC5
