PDA
View Full Version : Need help with memory wire
Grizzly0205
11-20-2006, 12:51 AM
hey i am hooking up a cd player in my new car where the person before cut the harness off so now i have to go thru and find which wire is which. I found ever wire but the memory so all i can do now just have the memory spliced with the power just so it will turn on. Does any one know another way i can get the memory wire to work and actually let me keep my radio stations programmed after I turn the car off??
TBSpyder
11-20-2006, 01:10 AM
Grab a multimeter and test for a constant, can't find one then go to the fuse box. If all else fails you can run a wire directly from your battery.
Grizzly0205
11-20-2006, 08:13 AM
o ok so the memory wire just needs to be hooked up 2 a hot wire that doesnt turn off??
GradeA_TireFryer
11-20-2006, 08:30 AM
check fuse under hood, these pop all the time!
TIM TIM TIM
11-20-2006, 05:17 PM
its just a 12v constant wire.. its not a smart wire or somthing
SOTO
11-20-2006, 11:52 PM
what kind of car is it?
Grizzly0205
11-21-2006, 12:06 AM
92 integra this is my first integra i have had civics crxs nissans but no integras. I havent even seen the fuse box yet
TBSpyder
11-21-2006, 03:16 PM
yup.
