lt1 clutch and flywheel
Old Nov 1, 2006 | 03:45 PM
kender's Avatar
gadget man
Default lt1 clutch and flywheel
I know that going too light on a flywheel isn't smart. On honda's I know that 8lbs is about as light as you want to go, but what about V8's? Also what material, I.E. aluminum or steel? what name brands of clutches and flywheels are good. I will be looking at a stage 2 or 4 clutch.
Thanks
U.S.S.A Crew Member #001
Old Nov 2, 2006 | 11:15 AM
B4C's Avatar
B4C
Track Star
Flywheel weight usually depends on use. Drag racing heavier than autocross for sure. I have an LT4 pressure plate, brand new for sale. You can use whatever disc you want. I drag race and have stayed with stock flywheel that weighs approx 19 lbs. Here is a link to an aluminum flywheel, but expensive LPE Light Weight Aluminum Flywheel Camaro, Firebird 1993-97: Lingenfelter Performance Engineering.
Keith
'94 Camaro B4C
Old Nov 2, 2006 | 01:38 PM
kender's Avatar
gadget man
It;s a daily driver with stop and go traffic, so I would like to be able to get up the rpms faster. I might go to the track every now and then, but this will be a street car. I plan on adding a supercharger in the future, something like the powerdyne or vortech units.
what is the stock flywheels weight?
Old Nov 7, 2006 | 07:18 AM
B4C's Avatar
B4C
Track Star
I think the stock flywheel is 19 lbs, with the lighter ones being 16 lbs.
The heavier flywheel will help with stop and go traffic. But 3 lbs is not much difference. Some cars are able to knock over 10 lbs off their flywheel weight.
Supercharger? N2O or rear mount turbo seem like better choices. But they all have their advantages. I chose the cheapest of the 3, N20 for $1000. And that includes tuning and all the safety switches. But if $ wasn't a factor a rear mount turbo for $4,400 would be the way to go.
Keith
'94 Camaro B4C
Old Nov 7, 2006 | 04:51 PM
kender's Avatar
gadget man
I've played the turbo game and for regular traffic the lag doesn't make it appealing. The nitrous isn't a bad game but I want my power on tap all the time without having to refill, not to mention having to arm it, so you need to know ahead of time that you want to use the power. With superchargers the lag is less than the turbo if at all depending on the SC and there is no refill necessary. I am looking for power to use at the drop of the hat to get in and out of traffic.
