240 ka timing
Old Oct 8, 2006 | 04:25 PM
smoke3's Avatar
Its a secret
Default 240 ka timing
how do i check a ka dohc motor to see if the timing is correct. What do the dot or square notches on the cam gears line up to when the crank is at tdc.
Anyone has a copy of the online manual the site is down
And if the time is off how do i go about and correcting the this. i really hope i dont have take the whole cover off to correct the timing.
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Oct 8, 2006 | 05:17 PM
RubberBerner's Avatar
Sideways Maffia
Does it run? does it just need a fine tune of the ignition timing, or is it the actual engine timing that is off? it won't run if the engine timing is off 95% of the time, it may run rough and a quick twist of the distributor could heal that.
NOBAMA!
Old Oct 8, 2006 | 05:35 PM
smoke3's Avatar
Its a secret
it runs it sounds boggy from until 3k then after than it has a good powerband.
I wanna start at the engine timing and make sure everything is perfect there before i mess with ignition but i dont have any resourses, im a honda guy
The Myspace Page
made.
- Its Game Time -
Old Oct 9, 2006 | 10:17 AM
steve's Avatar
madpom
on the crank its the 2nd line from the left
set it
open your oil cap or take valve cover off the cam lobe's shoud be pointing out
if not your 180' out
set the distributor to center and turn clockwise a bit
