LSD for a 92 S13
Old Oct 4, 2006 | 07:27 PM
murderZXfreak's Avatar
Exclamation LSD for a 92 S13
Whats the EZest LSD that i can drop onto a 92' S13. I read that J30 is the EZest but what all do i need off the J30? also is onlt the 95+ J30z only ones with the Visious LSD or do they all have Visious LSDs? or does the 95+ have VLSDs and 94- have LSDs? anyone that know really good info bout all this or know websites please post. Thers like 10 J30z in the junkyard here and i wanta drop it on my 240 ASAP.
Old Oct 4, 2006 | 07:33 PM
bender's Avatar
It's the name of my car..
The easiest LSD that can drop into an s13 is an s13 LSD. J30 LSD into s13 bellhousing is a hack and will work but one axle stub will stick out about 2mm more than it is supposed to. J30 drops right into an s14 though.
Epstein's little brother.
Car Specs:
White 95 Nissan 240sx SE SR20DET w/ 360whp
Red 2005 Nissan Sentra Spec-V
Human Specs:
Electrical Engineer
Old Oct 5, 2006 | 05:48 AM
SpottedMango's Avatar
Driven Concepts, Tampa FL
FYI -
Earlier model J30 VLSD 93~94.5 came with 5 bolt output shafts. In order for the VLSD to work, you will need the half shafts / axles.
Later model J30 came with the same 6 bolt output shafts as s13 and s14s.
Into s13 chasis, you will need to change out the rear cover. Simply replace the rear diff cover with the stock s13 one and you are good to go.
Into s14 chasis, it is a direct bolt in.
The easiest diff swap for a s13 would be a stock LE (or ABS equiped s13), it would be a direct bolt in with nothing needed to be changed out.
Driven Concepts, LLC
1101A East Hillsborough Ave.
Tampa, Florida 33604
813-236-4500
Monday - Friday 9am - 6pm
WE ARE DIRECT
Tein, GReddy, Buddy Club, Bride, Tanabe, K-Sport, Power Enterprise, etc......
https://www.tamparacing.com/forums/d...ml#post4905630
Old Oct 5, 2006 | 10:54 AM
170k240's Avatar
Will Drift For Tires
check it out: KA24DEvelopment.com :: VLSD Swap Information
Nissan North America - Canton
Old Oct 5, 2006 | 01:35 PM
OniS14's Avatar
do it BIG!!
goddam..say EASIEST...not 'EZest'...yew wee-tawd
florida is getting dumber and dumber every year...what the f*ck
S14 parts f/s
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
Old Oct 8, 2006 | 08:17 AM
will mccullough's Avatar
just weld your stock its cheaper but getto i heard the j30 diffs. eventually wear out and go back to open im not positive so research befor you buy one for 250 but if you find one at a junk yard it should be 50-100$ =)
Old Oct 10, 2006 | 08:20 AM
4wheeldriftS13's Avatar
February - Ride of the Month
lol I was going to post it if u didnt!
Its cause old yankee people die here and leave their young
RIP Tim Aldrich
Old Oct 10, 2006 | 01:49 PM
smokeyii's Avatar
Smokedogg
ROFL -- True.
BTW, noone else asked the question, but what are your plans with your car? That should always factor in when you're considering doing anything to your car.
If you want to drift like a pro, and you want your car done the "right" way, save up some cash and get a Kaaz or Cusco 2-way clutch type LSD. You'll be glad you did in the long run.
Old Oct 10, 2006 | 03:07 PM
But u dont necessarily need a 2-way LSD.
Vlsd's arent bad. But this guy seems to have just gotten into nissans because he's all like I need to drop me an LSD, which ones the EZiest? beginner drifter needs an LSD? Learn to drift the car STOCK then move on to an LSD. factory viscous are great.
RIP Tim Aldrich
