PDA
View Full Version : Cd not working
Big Chris
09-25-2006, 05:41 PM
I bought a used cd player and its not playing cds. It will when its in the mood, but I'm in the mood more then it is. Anyone have tips to clean it or should I just ponie up and buy a new onw.
TBSpyder
09-25-2006, 10:27 PM
It's worth a try to throw a cleaner cd in there...atleast it's cheaper than a whole new unit. Is an error code coming up or what? And are you trying to play burned cd's?
Big Chris
09-25-2006, 10:55 PM
A error code came up twice today, store bought cds. Tonight it played okay most of the night.
stompy
09-27-2006, 09:47 PM
what kind is it and what error code was it?
P057
09-28-2006, 12:38 PM
yeah, brand and describe how you wired it would help :)
TBSpyder
09-28-2006, 12:59 PM
How he wired it up wouldn't really affect it. It's most likely an internal problem.
stompy
09-28-2006, 01:38 PM
fyi if the unit is not grounded properly some will be able to do a lot of functions exept the cd part
example: grounded through the antenna
P057
09-28-2006, 02:34 PM
when i first started messing with my stereo i accidentally hooked A wire up wrong, can't tell you which, thats why i say A wire. Anyways the stupid thing would turn off halfway sucking the cd in and then the cd would get stuck in it. Then it would turn on and off and sit there cycling power, although you couldnt tell, only when the car was off and quiet you could hear it clicking and buzzing. Took a dismantling and fucking around with pieces of a cd player in order to figure it out. Wired it up properly the last time and then it worked fine, it couldve been that the ground was loosely placed, i dunno.
but yeh, best bet is the thing is just fucked and its time to throw the cd player at the seller and get another one
Notladstyle
09-28-2006, 03:39 PM
^^ this is true
TBSpyder
09-28-2006, 08:53 PM
It probably wouldn't be throwing an error message in that case.
Notladstyle
09-28-2006, 10:32 PM
why not? insufficient power to drive the servo I would assume has an error code.
TBSpyder
09-28-2006, 11:11 PM
I've yet to see that one.
stompy
09-29-2006, 01:02 AM
^this is also true.
Big Chris
10-13-2006, 11:19 PM
Tossed a cleaning cd in and it was working. Today I was listening to the radio and it just stoped playing, still on the station but no music then music then no music. If someone wants to fix this thing I have beer and cash.:D
Notladstyle
10-14-2006, 11:07 AM
that sounds like an internal amp problem. I would look at the wiring/RCA leads.
P057
10-14-2006, 11:35 AM
i would just get a new cd player, that sounds really gay.
Big Chris
10-16-2006, 10:33 PM
One of the door speakers came loose and caused it, the semi solid motor mounts I put in the car shoke it loose.
