Lets see your Zuks
From start to now.
Mine has YJ's, M/L front and rear, 5.14:1 tcase, ZOR front bumper, Trail Tough ext. drive shaft yoke, SpiderTrax Tcase arms, rear locker and a RRO Stage 1 OTT. The tires are 33X12.50X15 on 15X8's with 2.75 BS.
Nice tin top! Don't forget to post specs...I did
1990 Zuk
16 valve, 6.1 t-case, custom bumpers, Warn HS9500i, 1985 Yota axles, Detroits f/r, 5.29 gears, half doors, full cage...and then some, Yota rear drive shaft, rear discs, RE YG 2.5 inch springs, all pro high steer, Tracker power steering, etc...
1990 Zuk
Specs on mine are... 1.3 dt header,weber carb,dual friction clutch,5 to 1 next week shoould be here,5.13's with hybrid tracker rear end, 13 inch lift to clear 36 inch rubbers, ott steering,mighty kong,optima battery, shrock works sliders and bumpers, harbor freight 9,000 winch that needs to be mounted.
