PDA
View Full Version : need more help with the new sr
+Waldo+
08-21-2006, 09:10 PM
ok, its kinda scaring me, the power steering cable is just kinda hanging there, and now its leakin fluid bad, so ima fix that but after that started the car is now running rather odd... it runs perfect for like a hour but at time after a short ride it starts to bog super bad:( , its not turbo lag b/c i can hear/ feel the turbo spooling but like my rpms wont go up like its trying but it wont go...so guys whats this one sound like? thanks again for the previous advice:)
+Waldo+
08-22-2006, 07:06 PM
dose no one kno what that sounds like? u think it has to do with my power steering goin out or is it some thing enternal on the engine?
ph0tek
08-23-2006, 08:21 AM
Try nissan/infinty tech....
Sounds like not enough/too much fuel.
Bad filter,pump,sock...
Or bad spark, check plugs and timing.
+Waldo+
08-23-2006, 07:54 PM
thanks bud, it runs great when it first starts it just starts laggin later so i didnt think it would be fuel. ill post in there and see what they say
Addicted2Boost
08-30-2006, 03:06 PM
Also check timing couldnt hurt.
B18C5-EG
08-30-2006, 03:36 PM
Sounds like you blew your pump. If it was your filter it would raise in RPM's but if like you said it's not raigin then your pump is blown because it's not giving it any pressure.
buck19
09-02-2006, 04:28 PM
Does it idle irratically(sp) after it starts to bog?
+Waldo+
09-03-2006, 04:42 PM
no it idles fine, it bogs when i stop b/c of the bov, but just being stopped it idles perfect. the pump is not blown. it works fine after i started fillin it and got the ps fixed so i belive that was the problem. what would the irratic(sp) idle mean just wondering?
buck19
09-04-2006, 07:57 PM
It still does it after you fixed the ps or stopped?
Sohc4now
09-04-2006, 10:37 PM
when my car boosted up and wasnt going anywhere i assumed it was a drag somewhere. sure enough one of my calipers were stuck and i found it by driving for a while and once it started dragging i'd drive a lil more then check rotor temp with a laser thermometer
BluRRboSi
09-28-2006, 12:41 AM
WTF?
