PDA
View Full Version : just got a new Sr swaped 240, need some help
+Waldo+
08-14-2006, 07:05 AM
just purchased a 89' coupe with a redtop swap, its super clean and runs like achamp but it is grinding goin into 2nd gear and on some occasions it just dose not feel like the clutch is completly engaging. the last owner said he just put the sr stock clutch in. just wondering if anyone has heard of this or if its a common thing. appreciate any help
ph0tek
08-14-2006, 08:47 AM
First things first, check the slave and make sure its engaging, check your pedal make sure its adjusted.
Replace parts as necessary, make sure to bleed real good.
Secondly, I would replace the stock clutch as more then likely you are going to add to this car and the stock clutch is poo after 250-270 HP.
Last but not least, could be the 2nd gear synchro... If thats the case, replace or rebuild.
Good luck, its hard to diagnose on the internet but those are relatively common problems...
B18C5-EG
08-14-2006, 11:52 PM
Ya I reccomend bleeding the clutch with another person so you know it's done right, then I would go ahead and replace the tranny fluid. You also may want to replace all of the fluids in the car, you dont know how long it's been since the guy before you had done any of that. GL with the new car ^.^
Silvia_San
08-15-2006, 12:08 AM
new clutch, redline trans oil, bam!
+Waldo+
08-15-2006, 06:52 AM
ok sounds like a plan, thanks for the advice. i think its the syncro but then again it feels just like my clutch did on my last 240 b4 i had to replace the slave cylinder. ima get it up and work on it this weekend. also if anyone has a extra turbo timer pm m. thanks again
RoadRacer
08-18-2006, 08:49 PM
check the fluid level as it may be low. also, try double clutching.
Silvia_San
08-18-2006, 08:53 PM
actually GM Synchromesh Bam!
Paul
08-19-2006, 09:26 AM
actually GM Synchromesh Bam!Word?:)
Silvia_San
08-19-2006, 09:34 AM
yeah suppossedly it's really good. and it's a rebadged Pennzoil product i forget exactly what it's called. Pennzoil Synchromesh or something.
lunchbox
08-29-2006, 11:25 PM
that shit dont work ..
markzeronine
09-27-2006, 11:23 AM
Yeah sorry for the late reponse, but way back when I had my Integra the GM shit was all the hype. I tryed it and it ran nice for about 3months max, and when it started grinding again, my 2nd AND 3rd took a shit (before it was just second scratching) So I was pulling the ricer 1st- mmmmmBAHHHHHHHHHHHHHHHHHHHHHHH (winding out vtak till 8200), then 4th-buuuuuuuuuuuuuuuuuuh :lol:
sponsored
10-15-2006, 08:58 PM
bad tranny maybe?
drift180sx
10-20-2006, 12:23 AM
Dont forget to remove the clutch damper.!
marksaccord95
11-02-2006, 12:00 PM
if its having problems in most gears, then it might be clutch/hydroloic related. if its just in 2nd, its probably a bad tranny. 2nd gear is generally the 1st one to go.
agentAndy
11-25-2006, 02:17 PM
or 3rd if you are a man.
Matt Vassallo
11-26-2006, 02:12 PM
qft
CurbJacker
11-27-2006, 04:58 AM
Master cyl,Slave cyl,Steel braided clutch line. thats like 60 bucks for all 3 together. if it still does it after all that. then your trannys fucked.
