Car just shuts off??
Old Aug 9, 2006 | 02:06 PM
94DOHCDELSOL's Avatar
TR Balla Donor Supreme
Default Car just shuts off??
My car drives fine, it idles really low at the beginning though. When I let off the gas, the car shuts off. If I turn the key with the gas pressed down, it starts right back up. Even if I am going like 20mph, and just let off the gas, it shuts off. Any suggestions?
Old Aug 9, 2006 | 03:44 PM
anyone?
Old Aug 9, 2006 | 07:00 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Check your Idle air control valve. Its on the back of the throttle body. This is what is supposed to control your idle...
Is your CEL on?
Old Aug 10, 2006 | 05:48 AM
YBlegal's Avatar
Broke not Built
interesting...
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Aug 10, 2006 | 06:12 AM
Tightcivicexboii's Avatar
Honda Gear Head
Is your CEL on?
+1 I was going to recommend that his IACV aswell, seems like it is the only problem.. Just take it off and shake to listen and hear if the valve inside is loose. If not than thats your problem, because if it was too loose than it would be the problem but you'd be idling high, but it's the opposite so i'm guessing that your IACV is clogged and it'll be cheaper than you having an accident.
No project currently. Getting my ASE Certifications Completed.
Old Aug 10, 2006 | 11:57 AM
CIVICS55's Avatar
Check For Vaccum Leaks ,and Fuel Pump To If Working Properly
Old Aug 11, 2006 | 10:05 AM
ray123's Avatar
clean ur IACV with carb cleaner help idle a lot
Old Aug 11, 2006 | 06:06 PM
Brownsound's Avatar
Dude.. thats awesome.
Sounds like its the IAC
Old Dec 18, 2006 | 06:08 PM
jesus007's Avatar
have you checked your Idle Air control sensor?
Old Dec 18, 2006 | 06:36 PM
mug's Avatar
mug
Hey Mr Toilet Im The Shit
how bout your accelerator cable is it loose or worn out?
